Seat slider spring - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 12-05-2018, 07:54 AM Thread Starter
Premium Member
Jyuma's Avatar
Date registered: May 2017
Vehicle: 1983 380 SL
Quoted: 710 Post(s)
Premium Member
Seat slider spring
Any trick to reconnect that big ass'd spring under the seat?
Update: Never mind...
Nobody gets out of this life alive.
Jyuma is offline
post #2 of 14 (permalink) Old 12-05-2018, 08:12 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 106 Post(s)
Do you have brake spring pliers? They work. https://www.ebay.com/itm/1pcs-Brake-....c100005.m1851
rowdie is offline
post #3 of 14 (permalink) Old 12-05-2018, 08:13 AM Thread Starter
Premium Member
Jyuma's Avatar
Quoted: 710 Post(s)
Premium Member
Thanks Rowdie... I used my bottle jack.
Jyuma is offline
post #4 of 14 (permalink) Old 12-05-2018, 09:02 AM Thread Starter
Premium Member
Jyuma's Avatar
Quoted: 710 Post(s)
Premium Member
OK... for my next dumb question. I took the seats out over twenty years ago and I don't remember how the seats go back in. Do you first put the bottom seat in and then attach the back once everything is reconnected on the bottom or do you assemble the back to the bottom and then put the fully assembled seat in the car? Oddly enough I have one seat with the back attached and one seat with the back removed. Don't ask me why because I don't know.
bTw... I've been driving the car with the drivers seat just set more or less in the correct location... there is nothing holding it in. Dumb I know.
Jyuma is offline
post #5 of 14 (permalink) Old 12-05-2018, 09:13 AM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2371 Post(s)
I remove and install the seats in my car fully assembled.
Probably have done it 6-7 times over the years.
For some odd reason..... they are getting heavier.
Originally Posted by nobby View Post
Donítí ever wrestle with a pig. Youíll both get dirty, but the pig will enjoy it.
Originally Posted by rocky raccoon View Post
Soldier on Old Chap. The Pig is you and you are the Pig.
nobby is offline
post #6 of 14 (permalink) Old 12-05-2018, 09:15 AM
rowdie's Avatar
Quoted: 106 Post(s)
Assembled rails and all. Engage the hooks, put in front bolts, slide forward, install brackets on rear.
rowdie is offline
post #7 of 14 (permalink) Old 12-05-2018, 11:39 AM Thread Starter
Premium Member
Jyuma's Avatar
Quoted: 710 Post(s)
Premium Member
Thanks to all.
Jyuma is offline
post #8 of 14 (permalink) Old 12-05-2018, 12:37 PM Thread Starter
Premium Member
Jyuma's Avatar
Quoted: 710 Post(s)
Premium Member
I tried to do that for an hour today. The outside rail on the drivers side connects into the slot with no problem, but the inside rail refuses to go. I finally gave up.
I'm planning on removing everything again in the spring so I can eliminate the rust and paint with POR 15 or equivalent, so for now one side engaged in it's slot will just have to do.
Jyuma is offline
post #9 of 14 (permalink) Old 12-06-2018, 06:32 AM
Bob's Your Uncle!
nobby's Avatar
Make sure that your sliding rails are in the same position.
Also.....I'm pretty sure that I get the inboard rail set before the outboard.
I hate that job.
More than the oil change.
nobby is offline
post #10 of 14 (permalink) Old 12-06-2018, 12:49 PM Thread Starter
Premium Member
Jyuma's Avatar
Quoted: 710 Post(s)
Premium Member
I hate that job.
It doesn't help that a fully assembled seat has some mass to it so fine alignment adjustments are difficult to do.
As it turned out, having only one side engaged in it's slot is working fine... I even reinstalled the seat belt. Life is good.
@nobby … My car is running better and better each time I drive it. I'm not there yet but it looks promising for a road trip in the spring.
Jyuma is offline
