Check trans fluid level. Running? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 11-27-2018, 05:28 PM Thread Starter
Date registered: Sep 2016
Vehicle: 1981 380SL Walnut Brown
Quoted: 15 Post(s)
I have 1981 380SL and the transmission has a long shift between 2-3. But after a few shifts and the engine gets warm it shifts great.
So I checked the fluid tonight after letting the engine warm up to operating temp. Do you check the fluid with the engine running or shut off?
I did it both ways. First with the engine shut off and it looks like its too full, past the full line.
Then with the engine running and it looks low, see photo.
If its low, how much ATF do you recommend I add?
Thanks as always.
ODBuffalo is offline
post #2 of 4 (permalink) Old 11-27-2018, 05:37 PM
MBGraham's Avatar
Date registered: Oct 2006
Vehicle: '72 350SL, '85 300D, '98 E320, '19 Subaru Outback (sold '14 GLK250)
Quoted: 20 Post(s)
Should be running and done after short drive to warn transmission fluid up. Don't they have instructions in owners manual?
1972 350SL 4.5L, E320, 300D, Outback 2.5 - near Kingston, Ontario
MBGraham is offline
post #3 of 4 (permalink) Old 11-27-2018, 06:24 PM
RLT61's Avatar
Date registered: Jan 2016
Vehicle: 86 560SL
Quoted: 332 Post(s)
@GlueckAuf did an excellent write up about changing transmission fluid.
Here is the excerpt on how to fill to the correct level.
7. After driving the car for about 30 minutes, it should reach the prescribed 80 C/176 F operating temperature. Park the car in a level spot and leave the engine running. Move the transmission selector lever from P to R-N-D-N-R and back to P, pausing in each position for a few seconds. This ensures the servo pistons are filled with fluid. Recheck the transmission fluid level and gradually add the fluid necessary to bring it to the MAX level.
I tried to post the whole document, couldnít figure out how to do with the IPad.
RLT61 is offline
post #4 of 4 (permalink) Old 11-28-2018, 06:00 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 106 Post(s)
It's in the EGv107.
rowdie is offline
