Raw gas from Fuel distribution center - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 11-21-2018, 01:38 PM Thread Starter
Quanta2's Avatar
Date registered: Jul 2018
Vehicle: 1986 560SL
Quoted: 6 Post(s)
Should I be getting raw gas thru the rubber boot which ties the fuel distribution center to the lower plenum, or just air? Shouldn’t the gasoline be traveling via injector lines to injectors? I have gas running thru the boot and extreme over rich condition. Thanks for any advice!
Quanta2 is offline
post #2 of 4 (permalink) Old 11-21-2018, 01:43 PM
okyoureabeast's Avatar
Date registered: Mar 2017
Vehicle: 1984 380SL
Quoted: 606 Post(s)
No, that's not normal. It should pipe directly to the injectors.
I would check your cold start valve. It might be leaking.
okyoureabeast is offline
post #3 of 4 (permalink) Old 11-21-2018, 02:41 PM Thread Starter
Quanta2's Avatar
Vehicle: 1986 560SL
Quoted: 6 Post(s)
Isn’t the cold start valve on the front end of the manifold? I am asking, because I am not sure. What I think is the cold start valve would not leak into the rubber boot under the fuel distribution center. But I am not sure?
Quanta2 is offline
post #4 of 4 (permalink) Old 11-22-2018, 06:21 AM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2374 Post(s)
If I understand the symptoms that you are explaining ..... plunger in the FD....if it was leaking would be one of the only ways.
Originally Posted by nobby View Post
Don’t’ ever wrestle with a pig. You’ll both get dirty, but the pig will enjoy it.
Originally Posted by rocky raccoon View Post
Soldier on Old Chap. The Pig is you and you are the Pig.
nobby is offline
