560SL ... where do these Vacuum Lines go? - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 11-20-2018, 01:43 PM Thread Starter
cwmoser's Avatar
Date registered: May 2004
Vehicle: 1983 380SL, ivory/dk brown, 46k miles, dual roller timing chain. 1986 560SL, red/white, 190K mile.
Quoted: 1731 Post(s)
Was replacing Fuel Injectors in my 1986 560SL and
found a Vacuum Line that I can't figure out where it
goes. I plugged it off temporarily by putting on a rubber
joint and plugged with a screw.
The other end runs under the Fuel Distributor.
Where does this Vacuum Line go?
Photo is on the right side of the engine.
Carl
"You have chosen to drive a MERCEDES-BENZ, a car in whose construction and production we have taken great pains because we believe that quality is not a matter of chance." -- page 3, Owners Manual 380SL
Timing Chain, Subframe, wiring harness, Climate Control, Rust prevention, etc.
cwmoser is offline
post #2 of 12 (permalink) Old 11-20-2018, 03:05 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 106 Post(s)
Connects to the upper black hose for air cleaner.
rowdie is offline
post #3 of 12 (permalink) Old 11-20-2018, 04:01 PM Thread Starter
cwmoser's Avatar
This hose??
Carl
cwmoser is offline
post #4 of 12 (permalink) Old 11-20-2018, 04:15 PM
rowdie's Avatar
Quoted: 106 Post(s)
Yes
cwmoser likes this.
rowdie is offline
post #5 of 12 (permalink) Old 11-20-2018, 04:18 PM
RLT61's Avatar
Date registered: Jan 2016
Vehicle: 86 560SL
Quoted: 332 Post(s)
Nice job on the fuel injectors.
Here is a pic where the vacuum hose goes.
cwmoser likes this.
RLT61 is offline
post #6 of 12 (permalink) Old 11-20-2018, 04:50 PM Thread Starter
cwmoser's Avatar
Thanks @rowdie and @RLT61 .
Too dark in the Garage now for my 70 year old eyes to see.
First thing in the morning.
Carl
cwmoser is offline
post #7 of 12 (permalink) Old 11-20-2018, 07:40 PM
rcrmonte3's Avatar
Date registered: Sep 2011
Vehicle: 1974 450SL (always needs something!) new djet engine 1991; 1961 Besasie X-3 (being restored)
Quoted: 222 Post(s)
Sounds like the injectors were the right ones for the car. Glad we could get together.
cwmoser likes this.
rcrmonte3 is offline
post #8 of 12 (permalink) Old 11-21-2018, 04:10 AM Thread Starter
cwmoser's Avatar
Yes they fitted perfectly.
Thanks again Dennis - you helped me a lot with this.
Hope you got all issues work out with your SL.
Carl
cwmoser is offline
post #9 of 12 (permalink) Old 11-21-2018, 06:17 AM
Weather Man's Avatar
Date registered: Dec 2008
Vehicle: 1984 380SL
Quoted: 295 Post(s)
Carl, did you say you have no charcoal canister on the 560? What DO you have?
Weather Man is offline
post #10 of 12 (permalink) Old 11-21-2018, 06:27 AM
rowdie's Avatar
Quoted: 106 Post(s)
The 560SL has a charcoal canister they just hid it. It is under the fender. You have to remove the plastic splash guard to access it.
cwmoser likes this.
rowdie is offline
