New to BenzWorld Not my 560SL - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 10-28-2018, 08:47 AM Thread Starter
Date registered: Oct 2018
Vehicle: 1988 560SL
I have owned the 560SL for five years and have never had an issue. It has 77K on the clock.
This morning I took it out for a drive and the speedometer and odometer stopped working. The tachometer works like a champ.
I spent some time on this site searching for advice but my search skills must be lacking! Can anyone point me in the right direction. I love this car, my first Benz.
Seahawker is offline
post #2 of 13 (permalink) Old 10-28-2018, 09:27 AM
Hijak's Avatar
Vehicle: 1974 450SL, Dark_Blue/Parchment, 75K mi.
Quoted: 83 Post(s)
Not an expert but I’ve read about some plastic gears in the speedo/odometer that degrade and fail. If you do a search on your problem, especially in the sticky “the encyclopedia germanica” (spelling?), you should find your answer!
Hijak is offline
post #3 of 13 (permalink) Old 10-28-2018, 10:14 AM Thread Starter
Vehicle: 1988 560SL
Ouch!
Working it.
post #4 of 13 (permalink) Old 10-28-2018, 12:59 PM
NYYYCE&EEEEZY's Avatar
Date registered: Oct 2012
Vehicle: 1989 560SL; 2014 E350; 1960 190SL-sold; 1996 280C-sold
Quoted: 295 Post(s)
I'm thinking speedometer cable, but I'm no expert either.
If you haven't tried searching the 107 files and would like to...
Go to the main page for the 107 forum where all the threads are listed
Take note of the 2 black & blue bars running horizontally across the top of the page
On the right side of each black bar, there's a "search this forum" button
A small box will open up and you can type the search topic before clicking "GO"
The results will be one or more threads on the requested search topic...
unless there are no threads for the requested topic
If that happens, try using different search words
I've rarely run across a search that didn't yield at least some information
Here's a link for the search result using the words "speedometer and odometer failure"
https://www.benzworld.org/forums/sea...rchid=26571867
In the interim, some of the guys are likely to offer some advice of their own.
Good Luck!
Robert AKA: EEEEZY
You can't get us confused. I'm also "Nice", but NYYYCE is NEVER "Easy"!
The secret to happiness? Stay away from assholes!
NYYYCE&EEEEZY is offline
post #5 of 13 (permalink) Old 10-28-2018, 01:45 PM
Franklyspeaking's Avatar
Date registered: Feb 2015
Vehicle: 1998 C280; 1987 560SL
Quoted: 79 Post(s)
The odometer gears that break do not affect the speedometer. Mine were broken when I got my car, but the speedo still worked. The 560sl also has an electronic speedometer, so there is no cable. I would check the fuse first, but not likely if the the rest of the cluster is operating. Sorry I can't help more.
Franklyspeaking is offline
post #6 of 13 (permalink) Old 10-28-2018, 02:03 PM
cwmoser's Avatar
Date registered: May 2004
Vehicle: 1983 380SL, ivory/dk brown, 46k miles, dual roller timing chain. 1986 560SL, red/white, 190K mile.
Quoted: 1731 Post(s)
I had the same issue with the Speedometer in my 1986 560SL. Tried to fix it but could not.
Was not sure how to troubleshoot it - its an electronic speedometer, not cable.
I purchased another cluster ... not cheap.
If you figure out whats wrong with yours, post the solution.
Carl
"You have chosen to drive a MERCEDES-BENZ, a car in whose construction and production we have taken great pains because we believe that quality is not a matter of chance." -- page 3, Owners Manual 380SL
Timing Chain, Subframe, wiring harness, Climate Control, Rust prevention, etc.
cwmoser is offline
post #7 of 13 (permalink) Old 10-28-2018, 05:16 PM
okyoureabeast's Avatar
Date registered: Mar 2017
Vehicle: 1984 380SL
Quoted: 606 Post(s)
Paging Dr. @nobby Paging Dr. @nobby
Gears went bad. They always do. It's a very simple fix and shouldn't cost you more than $25.
Read this thread by the esteemed Dr. Nobby Benz-MD https://www.benzworld.org/forums/r-c...-tutorial.html
It has everything you need to fix this.
Good luck!
okyoureabeast is offline
post #8 of 13 (permalink) Old 10-28-2018, 06:47 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 106 Post(s)
Good luck!
True if only the odometer/trip meter but his speedometer is also not working. Franklyspeaking and Carl were correct.
rowdie is offline
post #9 of 13 (permalink) Old 10-30-2018, 10:30 PM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2374 Post(s)
I'm not familiar with the auto trani on the 560SL. But there should be a pick up / harness connected somewhere on the trani that the speedo and odo get their signal from.
I would start there and work your way towards the cluster.
Originally Posted by nobby View Post
Don’t’ ever wrestle with a pig. You’ll both get dirty, but the pig will enjoy it.
Originally Posted by rocky raccoon View Post
Soldier on Old Chap. The Pig is you and you are the Pig.
nobby is offline
post #10 of 13 (permalink) Old 11-07-2018, 07:49 AM Thread Starter
Vehicle: 1988 560SL
I would like to apologize. The speedometer works and I believe the second post below is the problem. I will work on it this weekend.
I can't thank you folks enough and again, I am sorry for the erroneous first post. I am what happens when cousins marry.
Best.
Good luck!
Weather Man likes this.
