Upper ball joint - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 10-07-2018, 08:47 AM Thread Starter
RLT61's Avatar
Date registered: Jan 2016
Vehicle: 86 560SL
Quoted: 332 Post(s)
Upper ball joint
I was under the impression that the ball joint of the upper control arm (year 86-89) can not be replaced. A few weeks ago I ran across an MB service manual (hard copy) for a 86 R107 on Craigslist and bought it. However a little research and it looks like nobody sells the ball joint by itself.
RLT61 is offline
post #2 of 6 (permalink) Old 10-07-2018, 03:07 PM
jlgottfred's Avatar
Date registered: Feb 2009
Vehicle: 1981 380SLC, 1993 E400 (Totaled stopping a cement truck) 1997 E420, 2003 E500
Quoted: 26 Post(s)
Yes the Top ball joint can be replaced as . I had to drill some pretty heavy duty rivits out, but the bolt on works just fine.
Here is the part:
https://www.autohausaz.com/pn/1153330827
$16 bucks, not too bad.
Here is what it looks like after replacement:
jsebastian likes this.
jlgottfred is offline
post #3 of 6 (permalink) Old 10-07-2018, 03:19 PM
jlgottfred's Avatar
Quoted: 26 Post(s)
Also, I would replace the lower ball joints. If the top are going most like the bottom are too. It's a nasty job, but you would be suprised how much better the car handles.
post #4 of 6 (permalink) Old 10-07-2018, 03:25 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 109 Post(s)
Here is the part:
Those won't work on a 560SL Upper A arm is totally different.
rowdie is offline
post #5 of 6 (permalink) Old 10-09-2018, 06:51 AM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2387 Post(s)
You participated in a thread a few years ago:
https://www.benzworld.org/forums/r-c...all-joint.html
Originally Posted by nobby View Post
Donítí ever wrestle with a pig. Youíll both get dirty, but the pig will enjoy it.
Originally Posted by rocky raccoon View Post
Soldier on Old Chap. The Pig is you and you are the Pig.
nobby is offline
post #6 of 6 (permalink) Old 10-09-2018, 03:11 PM Thread Starter
RLT61's Avatar
Vehicle: 86 560SL
Quoted: 332 Post(s)
Had to re-read the thread you posted the link to.
The purpose of this new thread was to point out that the Mercedes manual states that the ballpoint can be replaced, problem being Mercedes or any of the other vendor that I checked doesn’t sell the ball joint.
Maybe the moderators can join those two threads.
RLT61 is offline
