Post up Pics of your R107 mods, etc. - Page 3 - Mercedes-Benz Forum
post #21 of 28 (permalink) Old 09-03-2018, 09:35 AM
bigsky's Avatar
Date registered: Sep 2013
Vehicle: 1984 280sl 5spd, 02 E320 4matic, 79&79 450sl part-out, 78,79,81,83 300CD, 79 280CE
Quoted: 487 Post(s)
Originally Posted by RLT61 View Post
Car looks great. Nice list of desirable parts, especially the cat eye turn signals. What size tires do you have on the car?
Tire size 225-55-R16. Two of the rims are ET11, two are ET22
bigsky is offline
post #22 of 28 (permalink) Old 09-03-2018, 05:06 PM
Ianwright40's Avatar
Date registered: Dec 2015
Vehicle: 1973 450SL, 1999 c230
Quoted: 320 Post(s)
Cool
Originally Posted by RaceDiagnostics View Post
I installed seats from an Audi TT.
I made up these adaptors to fit to the original side mounts.
If your exhaust is as loud as your seats you will be getting a ticket.
Ianwright40 is offline
post #23 of 28 (permalink) Old 09-05-2018, 07:52 AM Thread Starter
RLT61's Avatar
Date registered: Jan 2016
Vehicle: 86 560SL
Quoted: 332 Post(s)
Thanks.
RLT61 is offline
post #24 of 28 (permalink) Old 09-05-2018, 09:10 AM
Date registered: May 2010
Vehicle: 1979 450SL UK spec
Quoted: 158 Post(s)
The seats are from a mk1 TT, so about 1998 to 2006.
This was my design, 25x25mm angle bar 5mm thick, probably an overkill but better to be safe than sorry.
Underside of the TT seat, its designed to be mounted to the floor.
I transferred the mounting holes from the old seats to the angle bar.
Trial fit.
Therfront mounting for the TT seat is not flat so needs to be adapted.
Cut with a hack saw.
Bent flat.
Welded up.
Another trial fit.
I had to cut out a notch due to the TT seat height adjuster.
Welded on captive nuts for front bolts.
Tack welded it together.
Double checked the fit.
All welded up and trimmed to shape with a strengthening piece welded below the notch.
Fitted in place.
Rear fixings.
Primed and painted black and the job was done, except I need to swap over the seat belt buckles.
I also plan to fit the heated seat loom and controllers from the TT.
After lacquer.
No radio? I plan to install a bluetooth amp instead and play radio/streaming etc from my phone
cwmoser likes this.
RaceDiagnostics is offline
post #25 of 28 (permalink) Old 09-05-2018, 06:17 PM
cwmoser's Avatar
Date registered: May 2004
Vehicle: 1983 380SL, ivory/dk brown, 46k miles, dual roller timing chain. 1986 560SL, red/white, 190K mile.
Quoted: 1743 Post(s)
Nice work.
Like to see some detailed pictures of those seats installed.
Carl
"You have chosen to drive a MERCEDES-BENZ, a car in whose construction and production we have taken great pains because we believe that quality is not a matter of chance." -- page 3, Owners Manual 380SL
Timing Chain, Subframe, wiring harness, Climate Control, Rust prevention, etc.
cwmoser is online now
post #26 of 28 (permalink) Old 09-06-2018, 10:31 PM
CavallinoRed's Avatar
Date registered: Apr 2008
Vehicle: 1988 560SL 50K
Quoted: 163 Post(s)
Just replaced the aftermarket radio with yet another aftermarket radio.
This one however looks a bit a bit more "Becker" but unlike a Grand Prix BE780 has CD/MP3,USB, Bluetooth & Cell Phone Hands-Free.
Currumbin SL likes this.
CavallinoRed is offline
post #27 of 28 (permalink) Old 09-07-2018, 03:19 AM Thread Starter
RLT61's Avatar
Vehicle: 86 560SL
Quoted: 332 Post(s)
Radio looks good. I thought about buying one of these last year but then decided to have the Becker refurbished. You probably did the smarter thing.
RLT61 is offline
post #28 of 28 (permalink) Old 09-10-2018, 06:04 PM
redghost's Avatar
Date registered: Oct 2012
Vehicle: 1972 220 D, 1974 450SL, 1995 E300D 2002 S430, 1976 300D, 1986 SDL, 1982 SD
Quoted: 446 Post(s)
Most of my "adjustments" have been deletes.
Remove the Disco Neon Sony radio
Remove the enormous boom box speakers in the rear footwell
Remove Cellular One antenna and phone
Remove spaghetti bowl of wires related to non standard electronics
Removed sheep skins
Remove chrome wheel arch trim
There were a few replacements
Replaced the perished center console and painted to match (sort of) original green interior
Replaced dials and switches from console which did not function
Replaced perished steering wheel with period correct
Replaced DOT headlamps with RoT lamps
Replaced perished tail lights
Replaced horse hair pads
Replaced 1990's Sony with Becker Mexico Cassette
Replaced perished dash speakers with NOS
Replaced black Bosch blades with bare metal
Replaced all injectors (Djet)
Replaced Trigger points, MAP and Dizzy
Replaced perished fuel pump
Replaced perished seat shiny bits on the sides
Replaced soft and hard top seals
Replaced undersize battery with Group 49
Replaced Alternator, starter and 00 gauge wires
Replaced soft and hard fuel lines
Replaced Brake hoses, lines and disks
Replaced window controls and motors
Replaced Gunsight rings
And some additions
Added Coco mats in green
Added trunk carpets in green
Added passenger side mirror
Added USB charging
Added Fog lamps that were a Delete on original order
Installed foil backed pad in place of perished hood pad scraps
DynaMat in trunk as well as cabin floors
Needs-
Windshield seals
Soft top update
Seat Belts rebuilt
Bilstein shocks all around
Down pipes and cross over
HVAC
Found out it was a bad idea
LED Lighting
Clay
74 450SL - Froggy
'86 300SDL - Polei
'82 300SD - Allen
Retired cars
'02 s430 - Victor
'76 300D - Voldemort
'95 E300D - Cleo
'72 220D - Gump
'87 300SDL - POS SDL
92 300SE - #1 boys ride
redghost is offline
