AC Fan Randomly Stops - Question - Page 2 - Mercedes-Benz Forum
post #11 of 19 (permalink) Old 09-03-2018, 02:02 PM
roncallo's Avatar
Date registered: Apr 2005
Vehicle: 1986 560SL with M120 V12 Engine, 1988 560SL Stock
Quoted: 297 Post(s)
Originally Posted by orbit398 View Post
Well, I swapped out the Temperature Regulator from another car and no change. Thinking it must be HVAC controller that has issues.
My next guess would be the push buttons.
roncallo is offline
post #12 of 19 (permalink) Old 09-03-2018, 06:22 PM Thread Starter
Date registered: Aug 2017
Vehicle: 1988, 560SL
Quoted: 43 Post(s)
What are suggesting to do? Are the push buttons replaceable. Or are there also spots to re-solder on them?
I tried to remove the cover surrounding the push buttons but appears I have to remove all the buttons so that can be removed. Is this true? I pulled hard on those buttons but they weren't coming off. The push buttons parts were under the large squarish circuit board. I wasn't sure on how to get that out of the way as I didn't want to break something. I see on your thread that you took yours completely apart; I just wasn't sure about taking it down further.
But appears I need to so I can get at the push buttons. Any pointers appreciated.
thanks
orbit398 is offline
post #13 of 19 (permalink) Old 09-04-2018, 04:26 AM
Date registered: Apr 2007
Vehicle: 300sl 1987
Quoted: 35 Post(s)
iirc if you didn't remove the push buttons you didn't gain access to the full double sided board to resolder *all* solder points (not only those you saw cracked with a magnifying glass). This was my go at it: Reparacion centralita AC - Foro Club w107 EspaŮa I would recommend taking it fully apart + temp wheel + fan speed 3 push button unit, repeat: completely apart and resoldering *all* points. My 2cts.
107's wiki:
Looking for original backseats + their hardware.
bereng is offline
post #14 of 19 (permalink) Old 09-07-2018, 03:30 PM Thread Starter
Quoted: 43 Post(s)
I think I found the issue with the AC & blower turning off whenever it wants. The electronic connection at the end of the key switch seems to be the culprit. Jiggling the key when the blower/AC compressor have stopped, seems to make them restart. Plan to replace the end of the key switch and hope this solved the issue.
But, now that the AC system is running, I am getting water on the floor board. All four drain pipes are clear. It's the joint between the lowest AC evaporator box piece and the one it connects too.
Of course the car just keeps presenting problems, never stops.....
orbit398 is offline
post #15 of 19 (permalink) Old 05-10-2019, 06:03 PM
willyusa's Avatar
Date registered: Dec 2017
Vehicle: 1988 560SL - 79K miles
Quoted: 5 Post(s)
Orbit, did replacing key terminal fix it? I have the exact same issue! Started taking out the AC controller unit and read your post... I'll be dammed if by jiggling the key the AC doesn't start blowing... the most absurd thing....
willyusa is offline
post #16 of 19 (permalink) Old 05-10-2019, 07:31 PM
Franklyspeaking's Avatar
Date registered: Feb 2015
Vehicle: 1998 C280; 1987 560SL
Quoted: 78 Post(s)
Must be a common problem. Mine does the same thing. After starting the car, I turn the key ever so gently counterclockwise and the blower starts blowing. I wonder what they charged for this option!
Franklyspeaking is offline
post #17 of 19 (permalink) Old 05-10-2019, 07:48 PM
willyusa's Avatar
Quoted: 5 Post(s)
From what I gather, it's the ignition switch that must have a lose contact... some other folks report getting engine shutdown, etc.... so it can affect accessory systems (AC, radio, etc. or engine). I might get a replacement ignition switch and see if that does the trick...
willyusa is offline
post #18 of 19 (permalink) Old 05-10-2019, 07:52 PM
okyoureabeast's Avatar
Date registered: Mar 2017
Vehicle: 1984 380SL
Quoted: 575 Post(s)
If it makes you feel better orbit, my car pees on me too. Drain plugs are clear.
I wonder if it has something to do with non operating vent flaps. I got mine all working but its not humid enough to condense yet. So no idea.
okyoureabeast is offline
post #19 of 19 (permalink) Old 05-14-2019, 06:21 AM
Vehicle: 300sl 1987
Quoted: 35 Post(s)
Oh wow didn't know about the ignition switch.
Mine drips water from the condensation on the AC piping and it's insulation peeling off. Amend insulation. I notice by driving with sandals where freezing water would drip on my toes! Try the sandals test lol
107's wiki:
bereng is offline
