Reliability 560SL - Page 2 - Mercedes-Benz Forum
post #11 of 28 (permalink) Old 07-18-2018, 09:28 PM
rcrmonte3's Avatar
Date registered: Sep 2011
Vehicle: 1974 450SL (always needs something!) new djet engine 1991; 1961 Besasie X-3 (being restored)
Quoted: 222 Post(s)
My 450SL does the same thing. Nothing to worry about.
rcrmonte3 is offline
post #12 of 28 (permalink) Old 07-18-2018, 09:38 PM
It Is What It Is, Dude
isthisdave's Avatar
Date registered: Mar 2006
Vehicle: 1978 107.024 RIP
Quoted: 108 Post(s)
Originally Posted by Quanta2 View Post
Thanks for the good advice. I have a newbie question. On my 560, if it fails to start on the first try, the starter will not engage again unless I turn the key to the off position first, then rotate to start again. Is yours like this? Or is this something wrong with mine?
It's a German thing, seen the same in VWs and Porsches of the era
isthisdave is offline
post #13 of 28 (permalink) Old 07-19-2018, 04:29 AM
jaymaynard's Avatar
Date registered: Mar 2013
Vehicle: 2015 ML250 Bluetec, 62K miles; 1987 560SL, 121K miles
Quoted: 715 Post(s)
That's not a bug, that's a feature. Older Mercedes have a mechanical interlock to prevent the key being turned to the start position a second time unless it's turned all the way off first. Later ones with Drive Authorization Systems (those fancy electronic keys) don't keep you from turning the key to the start position, but since the start is done entirely under computer control, it will simply refuse to attempt another start unless you turn the key all the way off.
"Engineered like no other car in the world." That's both a bug and a feature.
jaymaynard is offline
post #14 of 28 (permalink) Old 07-19-2018, 05:11 AM Thread Starter
Quanta2's Avatar
Date registered: Jul 2018
Vehicle: 1986 560SL
Quoted: 6 Post(s)
Thatís a relief!
Thanks
Quanta2 is offline
post #15 of 28 (permalink) Old 07-19-2018, 05:55 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 109 Post(s)
Originally Posted by rcrmonte3 View Post
Eventually the car died and wouldn't restart. Finally found a working ECU that matched the 1 in the car. Replaced ECU. Car works fine now. There are a couple members here who might have one. But check everything else first. Also, you have to check the voltage to/from EACH terminal (pin) on the ECU. I don't think there's a relay that feeds it. Also, if the ignition has a fault, the ECU would work only when the ignition switch is fully functional. Ignition switch and circuits are easier to trace and less expensive to fix. If there is low voltage to 1 or more of the pins on the ECU, trace those circuits 1st and make any repairs. If none of the repairs help, or if there are no faults in the circuitry, it's the ECU.
The 560 has a totally different system. Yours is electronic injection. The 560 is not. There is a relay for your ECU. On the '73 t is the second one down on the right side of the relays just below the FP relay. Probably the same on yours. Your ECU is on the firewall, the 560 has a different type below the right side floor under the carpet.
rowdie is offline
post #16 of 28 (permalink) Old 07-19-2018, 06:23 AM Thread Starter
Quanta2's Avatar
Vehicle: 1986 560SL
Quoted: 6 Post(s)
Hey thanks Rowdie! On the 560, the ECU is under the carpet? And is there an ECU relay feeding it? Thanks again!
Quanta2 is offline
post #17 of 28 (permalink) Old 07-19-2018, 07:29 AM
rowdie's Avatar
Quoted: 109 Post(s)
I should have said it is under a plastic cover under the carpet.
I don't know about a relay. Maybe it is in the online manual wiring diagram.
rowdie is offline
post #18 of 28 (permalink) Old 07-19-2018, 08:17 AM
JS5D's Avatar
Date registered: Dec 2016
Vehicle: 1983 380SL
Quoted: 86 Post(s)
The idea being that (with such a quiet engine) you don't try to start a running engine. Lesser cars would give you that unpleasant scraping sound of the stater gear trying to mesh with a turning flywheel.
I am trying to teach my teenage kids that they need to LISTEN to the engine starting before then releasing the key, unlike our modern cars where it is all done by the computer, you can flick the key (my son) or just hold hit there for 30 sec (my daughter). Old cars are just sooooo complicated - whatever..
jsebastian likes this.
JS5D is offline
post #19 of 28 (permalink) Old 07-19-2018, 08:53 AM
rcrmonte3's Avatar
Quoted: 222 Post(s)
Thanks for the info Rowdie. That was my experience.
post #20 of 28 (permalink) Old 07-24-2018, 03:54 PM
Date registered: Jul 2010
Vehicle: 2006 E350, 2007 SL550
Quoted: 5 Post(s)
You mentioned that you replaced the old tires but did you replace the other old rubber items such as hoses and belts? For a car that old (I owned one) rubber does not get better with age and blowing a hose of belt at speed is not recommended and will downgrade the reliability factor. I'd replace all!
ronjohnstone is offline
