Wheel spacers and lug bolts - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 06-26-2018, 12:05 PM Thread Starter
RLT61's Avatar
Date registered: Jan 2016
Vehicle: 86 560SL
Quoted: 332 Post(s)
A few weeks ago I ended up purchasing a set of R129 wheels. Based on everything I read on this forum I will need 20mm spacers.
Is there a company that makes wheel lug bolts just as in the picture below but with a 20mm longer threaded section for a total length of 60mm?
RLT61 is offline
post #2 of 10 (permalink) Old 06-26-2018, 01:43 PM
reno4u2's Avatar
Date registered: Dec 2009
Vehicle: 1988 560SL (California Model)
Quoted: 838 Post(s)
You might try Otis Inc. LA Generally speaking if they don't have it it probably isn't made. I used custom adapters on mine only I needed 25mm to clear the front caliper. They're not really adapting anything but would give you a bigger choice in lug bolts. IIRC the owner's name is Lenny...
Wheel Adapters, Wheel Spacers, Hub Rings, and much more! | Motorsport Tech
reno4u2 is online now
post #3 of 10 (permalink) Old 06-26-2018, 02:34 PM
Franco380's Avatar
Date registered: Sep 2017
Vehicle: 1985 380sl
Quoted: 23 Post(s)
Are those the 8 x 16" wheels? IIRC I tried to use 10mm spacers to clear the tie rod ends on mine. They were not hub centric and wobbled. Lugs are available in lots of lengths fortunately.
Franco380 is offline
post #4 of 10 (permalink) Old 06-26-2018, 03:37 PM Thread Starter
RLT61's Avatar
Vehicle: 86 560SL
Quoted: 332 Post(s)
Thanks for posting the links.
RLT61 is offline
post #5 of 10 (permalink) Old 06-26-2018, 03:38 PM Thread Starter
RLT61's Avatar
Vehicle: 86 560SL
Quoted: 332 Post(s)
Yes, 16 x 8 ET34
RLT61 is offline
post #6 of 10 (permalink) Old 07-16-2018, 06:15 AM Thread Starter
RLT61's Avatar
Vehicle: 86 560SL
Quoted: 332 Post(s)
Followed-up with Motorsport-Tech, the company @reno4u2 recommended, and talked to Lenny about what I am trying to do.
He recommends custom spacers 23mm thick with helicoils. The spacer would mount to the hub and the wheel mounts to the spacer.
As stated in my first post I want to use the R129 wheel (see pic.)
There are several benefits going this route:
1. Wheels size 8x16 ET34 with 23mm spacer - effective ET=11.
2. The R129 wheel uses the same bolts as the wheel that is currently on the car. No need to purchase new bolts.
3. I can keep my current spare wheel and donít need to pack extra wheel bolts. I will need to remove the spacer in case of a flat tire.
4. The head of the wheel bolt will be flush with the surface of the wheel.
5. Price of the custom made spacers (4) is $320 shipped, which is about 1/3 more than quality spaces from H&R but I donít need new bolts.
Are there any major concerns going this route?
reno4u2 likes this.
RLT61 is offline
post #7 of 10 (permalink) Old 07-16-2018, 06:52 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 106 Post(s)
Mercedes stopped selling the original bolts due to the upper shank breaking. The upper shank above the ball seat was eliminated. The heads of the replacements sit deeper into the hole.
rowdie is offline
post #8 of 10 (permalink) Old 07-16-2018, 07:03 AM Thread Starter
RLT61's Avatar
Vehicle: 86 560SL
Quoted: 332 Post(s)
Thanks for the info. I was not aware of the problem, but it does make sense. That would be a real pain in the behind to get the wheel off if one of the bolts breaks.
RLT61 is offline
post #9 of 10 (permalink) Old 07-16-2018, 07:36 AM
jaymaynard's Avatar
Date registered: Mar 2013
Vehicle: 2015 ML250 Bluetec, 59K miles; 1987 560SL, 121K miles
Quoted: 710 Post(s)
Yep. The folks on the 210 forum recommend preemptively replacing all of them. Apparently, getting a broken bolt out without damaging the wheel is nearly impossible.
"Engineered like no other car in the world." That's both a bug and a feature.
jaymaynard is offline
post #10 of 10 (permalink) Old 07-16-2018, 09:39 AM
Fonzi's Avatar
Date registered: Jun 2010
Vehicle: 450slc5.0cab 280sl5sp 280se4.5 500seAMG +250seStkW108 350sl4spdX3 500secEuro
Quoted: 2341 Post(s)
I got very lucky on a w124 wagon that had seized extended bolts. I could feel them starting to yield, and decided to take precaution. Lots of penetrant and heat from the back side of the rotor was the solution, and I was able to get the wheel off without breaking any bolts. If anyone had gone after that bolt not knowing the issue, I probably would have scrapped the car with the wheel on it.
My signature:
If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
