No start after filter replacement fuel distributor - Page 19 - Mercedes-Benz Forum
post #181 of 186 (permalink) Old 04-27-2019, 12:04 AM
miko1aj's Avatar
Date registered: Sep 2012
Vehicle: '79 450SL, '04 CLK200 convertible; former A124, W210, A209.
Quoted: 100 Post(s)
Same here, absolutely one of the best threads - and I don't even have a KEjet! 😂
H.D. and Bauk18 like this.
miko1aj is offline
post #182 of 186 (permalink) Old 04-29-2019, 05:16 AM Thread Starter
Bauk18's Avatar
Date registered: Apr 2017
Vehicle: 560SL 1986 244k miles astral grey / black
Quoted: 99 Post(s)
@miko1aj & @luckymike Many thanks for the support!!
Originally Posted by H.D. View Post
Without going into too much detail , the acceleration enrichment works like this:
When the throttle valve abruptly opens to a significant degree, the AFM plate abruptly jumps down to a significant degree. The AFM potentiometer informs the CIS-ECU about that. The CIS-ECU, knowing (respectively in the test “thinking“) that the engine temperature is 20°C, reacts by sending a current of at least 20 mA (depending on the abruptness of the acceleration) in positive direction through the EHA‘s coil. That moves the EHA‘s baffle plate (depending on the amperage) closer to the EHA‘s inlet nozzle. That reduces the fuel flow through the EHA. That decreases LCP (significantly). That increases the pressure difference between LCP & UCP. That decreases UCP (slightly), thus increasing the difference between UCP (on one side of the metering slits) & SP (on the other side of the metering slits). And that is what causes increased fuel flow through the FD‘s metering slits and, consequently, to the injectors.
@H.D. This is a real brain cracker and more difficult to understand then the French tax declaration I filled this weekend...
Anyhow, whilst performing the TPS tests specified in the FSM I ran into difficulties with the wire test between ECU < -- > Idle control module (N8) < -- > TPS connector (S29/2x). The idle control module is a PIA the reach anyhow, but how to reach it with a MM? Anyone a clever idea? Can the socket were the ICM sits in be declipped?
THXB
How hard can it be?
Bauk18 is offline
post #183 of 186 (permalink) Old 05-01-2019, 03:19 AM
jaymaynard's Avatar
Date registered: Mar 2013
Vehicle: 2015 ML250 Bluetec, 57K miles; 1987 560SL, 121K miles
Quoted: 702 Post(s)
I'm loving this thread too, and I do have a KE-Jet...the car runs great is it is, but I find myself wondering if I need to run some basic checkouts, just to make sure it's doing right.
"Engineered like no other car in the world." That's both a bug and a feature.
jaymaynard is offline
post #184 of 186 (permalink) Old 05-02-2019, 03:42 AM
Date registered: Apr 2007
Vehicle: 300sl 1987
Quoted: 35 Post(s)
^Yeah. After 35-ish years I am sure a sanity check is due. But I don't know where to start and through a 'safe' path that will be conservative rather than big-bang, to avoid getting myself in a mess I can't solve and loose the car...
107's wiki:
Looking for original backseats + their hardware.
bereng is offline
post #185 of 186 (permalink) Old 05-02-2019, 12:32 PM
H.D.'s Avatar
Date registered: May 2014
Vehicle: 1988 300CE
Quoted: 509 Post(s)
@Bauk18:
If I would not have logged in, I would not have found out about your & the other member‘s new posts. Until the forum is repaired & works properly again for not logged in visitors, please send me notifications about new posts to the private email address I sent you via PM. With only sporadically receiving email notifications from BW, I may not notice otherwise. …
Originally Posted by Bauk18 View Post
@... H.D. This is a real brain cracker and more difficult to understand then the French tax declaration I filled this weekend... ...
If you track what I said in post 179 on a sectional drawing of the KE-Jetronic‘s FD you‘ll realize:
  • that it‘s actually easier to understand than a tax declaration.
  • that the pressure difference between the variable UCP (Upper Chamber Pressure) on one side and the constant SP (System Pressure) on the other side of the FD‘s metering slits is the key to understanding the E‘s part (!) of the KE-Jetronic‘s air/fuel mixture control in general (not only for acceleration enrichment). That pressure difference is indirectly controlled by the volume flow through the EHA, which directly controls the difference between LCP (Lower Chamber Pressure) & UCP.
  • and that, no matter how often you hear or read about “checking the upper chamber pressure“ on CIS-E cars, the upper chamber pressure can not be checked. … (see what I said about that in post 12 of this thread: https://www.benzworld.org/forums/w12...l#post17551181)
@jaymaynard & @bereng:
Originally Posted by jaymaynard View Post
... I find myself wondering if I need to run some basic checkouts, just to make sure it's doing right.
That‘s especially recommendable if the Lambda adjustment screw has been tinkered with or if you don‘t known whether it has been tinkered with or in what direction & how far it has been turned, respectively what the duty cycle was before it was turned.
See what I said in post 8 of this thread: https://www.benzworld.org/forums/r-c...uty-cycle.html
The least that should be (frequently) done anyway, but is inexplicably often ignored, is to check the duty cycle … (under the conditions mentioned in that same post). … Further tests depend on the results of that duty cycle check.
H.D.
P.S.: In order to keep this thread focused on the OP‘s issues I suggest to post results, if any, in a separate thread.
H.D. is offline
post #186 of 186 (permalink) Old 05-13-2019, 06:15 AM Thread Starter
Bauk18's Avatar
Quoted: 99 Post(s)
To all dear followers,
Just to let you know I haven't given up on my KE. I need Frank to be ready for the weeding of my sister in 4 weeks time so shifted my focus on a few other projects:
- Changed the diff from 2,48 to 2,24 ratio and new seals
- Manifold & area clean + new donuts & gaskets
- Finalised electric cooling fan project
- Installed rear spoiler
- Valve covers in wrinkle red
- Fit bundt style rims
- Install Euro bumpers
The last 3 are in progress. I'll report back here once the above list has been completed and once I have completed a full TPS test.
THXB
How hard can it be?
Bauk18 is offline
