Shocks and Springs, is there a consensus? - Page 2 - Mercedes-Benz Forum
post #11 of 27 (permalink) Old 05-22-2018, 03:54 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 111 Post(s)
Originally Posted by ehawk01 View Post
Do the springs also need replacing when the shocks are replaced?
No.
Sachs Boge may be OE.
ehawk01 likes this.
rowdie is offline
post #12 of 27 (permalink) Old 05-23-2018, 01:54 PM
Date registered: Apr 2013
Vehicle: 1987 560SL, 2011 E350 Wagon, 2016 AMG GTS Edition 1, Ural Gear Up
Quoted: 41 Post(s)
In all probability, your springs are fine.
You won't be disappointed with Bilsteins.
The springs I removed from my '87 with 65k miles looked and performed as new.
H&R offers a set that drops the front 50mm but raises the rear 15mm...not sure how I feel about that rake yet...might return to stock.
ehawk01 likes this.
mshea is offline
post #13 of 27 (permalink) Old 05-24-2018, 09:29 AM
Date registered: Jun 2011
Vehicle: 75, 280Sl /5speed
Quoted: 279 Post(s)
I am probably going to put less than 3000 miles on the car each year also. I am curious to know if anyone has strayed from Bilsteins and if they worked out OK or not.
I have been running Koni adjustables with SPAX lowering springs for 6 years. Not
cheap but no complaints.
https://www.koni-na.com/en-US/NorthA...505&mk=26&mt=1
ehawk01 likes this.
107merc is offline
post #14 of 27 (permalink) Old 05-24-2018, 02:49 PM
Date registered: Apr 2006
Vehicle: 1983 380SL, 2000 S430, 1991 420SEL (retired) - RHD
Quoted: 387 Post(s)
Smile Non Bilstein Shocks
I got Sachs and they seem fine. The reason I say "seem" is that I'm only doing normal (unstressed) driving. However, My indie thinks they are good.
ehawk01 likes this.
Aussiemerc is offline
post #15 of 27 (permalink) Old 05-24-2018, 04:16 PM Thread Starter
ehawk01's Avatar
Date registered: Feb 2016
Vehicle: 1983 380SL
Quoted: 73 Post(s)
Does it make sense to replace the steering damper at the same time?
ehawk01 is offline
post #16 of 27 (permalink) Old 05-24-2018, 05:29 PM
RLT61's Avatar
Date registered: Jan 2016
Vehicle: 86 560SL
Quoted: 332 Post(s)
I replaced mine at the same time I installed the idler arm rebuilt kit. I don’t know if it needed to be replaced or not but it was 30 years old, the part was cheap enough and easy to install.
RLT61 is offline
post #17 of 27 (permalink) Old 05-24-2018, 07:45 PM
PanzerPuff's Avatar
Date registered: Dec 2013
Vehicle: 1987 560SL
Quoted: 871 Post(s)
Originally Posted by RLT61 View Post
Buying shock absorbers is one of those purchases that can get confusing. I wanted to limit the unknowns and based my decision on the reputation of Bilstein and the feedback from members on this forum. I also like a little bit of a firmer ride so I chose HDís for the rear shocks.
I believe @PanzerPuff has KYBís
Yes I had KYB's on my 450SL and have Bilsteins on my 560SL. The ride was about the same; the primary difference was the KYBs cost less at the time.
Yes only if the steering damper is shot. Just disconnect one end of the damper and push and pull. You should feel significant resistance. If you can move it stop to stop in a few seconds the damper is done, replace it.
ehawk01 likes this.
PanzerPuff is offline
post #18 of 27 (permalink) Old 06-06-2018, 06:27 PM
Franco380's Avatar
Date registered: Sep 2017
Vehicle: 1985 380sl
Quoted: 23 Post(s)
Quick question: why comforts on the rear?
Franco380 is offline
post #19 of 27 (permalink) Old 06-07-2018, 10:26 AM
304065's Avatar
Date registered: Jan 2012
Vehicle: 2011 S212, 1978 R107
Quoted: 45 Post(s)
Ideally the shock valving should be matched to the spring rate. This accounts for different valving (HD, Comfort) front-to-rear.
Where it gets complicated is when the spring rates have changed, either through fatigue, coils removed, or aftermarket springs.
Ideally you would put the shocks on a shock dyno to measure them and then match to the revised suspension (including spring and bushing changes)
Of course that's an ideal. . . not sure I have heard of anyone in the R107 community who has done this.
2011 S212 E350 Tansanitblau
1978 R107 450SL 735 AstralSilber
304065 is offline
post #20 of 27 (permalink) Old 06-08-2018, 04:59 PM
Date registered: Mar 2016
Vehicle: 1985 Euro 380SL
Quoted: 64 Post(s)
peter.k is offline
