Lesson learned - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 05-11-2018, 06:59 PM Thread Starter
Premium Member
Jyuma's Avatar
Date registered: May 2017
Vehicle: 1983 380 SL
Quoted: 759 Post(s)
Premium Member
Lesson learned
I've heard it said many times... new parts can be bad too.
Today I spent 3 or 4 hours bleeding my new brakes. Everything at the wheels is new or rebuilt, but I just couldn't get brake fluid to flow to the rear brakes. I figured the entire system was empty so maybe it would take a while for the fluid to get to the rear brakes... so I pumped and pumped and pumped but nothing. Long story short... one of the new self bleeders was bad. WHAT? Yup. The way I found it was by running up to Harbor Freight and buying a hand operate vacuum pump that can be used for many things requiring vacuum, including bleeding breaks. I put the gizmo on the right rear brake and pumped away on the handle but got nothing. I then moved to the left rear brake and managed to pull fluid from the master cylinder. I moved back to the right rear brake and again... nothing. I removed the bleeder entirely and fluid started dripping out of the caliper. I put the old non-self bleeder in, attached the pump and presto... fluid galore. The damn self bleeder wouldn't bleed. The other 3 worked ok but the 4th one nadda.
So it's true... new parts can be bad too. I wish I had thought of that 2 hours sooner.
cwmoser and yka like this.
Nobody gets out of this life alive.
Jyuma is offline
post #2 of 8 (permalink) Old 05-11-2018, 10:01 PM
jsebastian's Avatar
Date registered: Sep 2011
Vehicle: 1967 250 S (sold) 1986 560 SEC 1987 560 SL
Quoted: 129 Post(s)
Nice to hear that you got it sorted! There is nothing quite as annoying as new defective parts....
John
jsebastian is online now
post #3 of 8 (permalink) Old 05-12-2018, 07:52 AM
ejboyd5's Avatar
Date registered: Jun 2009
Vehicle: 1955 300 SL
Quoted: 175 Post(s)
I once encountered a bleed valve (brand new) that did not have the passage completely drilled. Very difficult to move fluid through a solid screw. Also had the same problem with a windshield washer nozzle.
ejboyd5 is offline
post #4 of 8 (permalink) Old 05-12-2018, 01:14 PM Thread Starter
Premium Member
Jyuma's Avatar
Quoted: 759 Post(s)
Premium Member
Yup. Metal is a very poor conductor of fluid.
Jyuma is offline
post #5 of 8 (permalink) Old 05-14-2018, 08:56 AM
Premium Member
Date registered: Sep 2017
Vehicle: 1985 380SL
Quoted: 50 Post(s)
Premium Member
I've been a bit leery of the speed bleeders as I don't trust the seal on the threads to be air tight and I don't like pushing the master cylinder piston into places it never goes. I went to a pressure bleeder and never looked back. These things are awesome and super easy to use. The one I got is at the link below but there are a number of sellers out their.
https://mercedessource.com/store/pressure-brake-bleeder
MrSpock is offline
post #6 of 8 (permalink) Old 05-14-2018, 08:56 AM
Premium Member
Vehicle: 1985 380SL
Quoted: 50 Post(s)
Premium Member
MrSpock is offline
post #7 of 8 (permalink) Old 05-14-2018, 09:31 AM Thread Starter
Premium Member
Jyuma's Avatar
Quoted: 759 Post(s)
Premium Member
I bought the cheap Harbor Freight hand operated vacuum pump for a few reasons...
1. It's cheap. I'll use it maybe 10 times in my life.
2. It does more than just bleed brakes. You can also troubleshoot vacuum problems with it.
3. Kent does a great job on his videos but damn... is there anything he doesn't market a kit for?
I'm waiting for the Mercedes Source kit for neutering your cat.
Currumbin SL likes this.
Jyuma is offline
post #8 of 8 (permalink) Old 05-15-2018, 12:05 PM
Walt Williams's Avatar
Date registered: Dec 2015
Vehicle: 1983 380SL (us), Former owner: 1965 190Dc
Quoted: 440 Post(s)
If your going to do this how about getting and additional brake cylinder reservoir cap and fitting it with a schrader valve, turn your air compressor do to like 20#, and use that to bleed your brakes. That actually sounds like a slick idea.
Walt Williams is offline
post #9 of 8 (permalink) Old 05-16-2018, 01:54 AM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2411 Post(s)
Ala Nobby?
I use a 7 gallon pig with the regulator set at 15-20 psi.
nobby is offline
