W107 SL450 engine unclear block hole - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-09-2018, 12:17 AM Thread Starter
Date registered: Jan 2018
Hi,
Could you please help to indetify for what reason is hole in my SL450 engine block. I marked it in picture with red circle. Through this hole is leaking coolant. Thanks!
ID:	2349498   Click image for larger version
Mindaugas Sokas is offline
post #2 of 5 (permalink) Old 01-09-2018, 05:52 AM
Weather Man's Avatar
Date registered: Dec 2008
Vehicle: 1984 380SL
Quoted: 298 Post(s)
I see a drip pan but no red circle.
Weather Man is offline
post #3 of 5 (permalink) Old 01-09-2018, 07:01 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 109 Post(s)
I had trouble too. It is on the side to the rear of the block. Faint and looks pink on my monitor.
Just a guess but could be connected to the drain hole at the rear of the valley beneath the intake. https://www.benzworld.org/forums/r-c1...ml#post4928422
Mindaugas Sokas. Welcome to the forum. Click on the User CP button above and complete your profile with year, model, and location. Looks like you have a '75 or '76 450SL/C.
rowdie is offline
post #4 of 5 (permalink) Old 05-16-2019, 02:35 AM
Date registered: May 2019
Did you figured out what is that hole? Mi car has a small oĆ*l leak coming from there
ccrokov is offline
post #5 of 5 (permalink) Old 05-16-2019, 08:04 PM
roncallo's Avatar
Date registered: Apr 2005
Vehicle: 1986 560SL with M120 V12 Engine, 1988 560SL Stock
Quoted: 297 Post(s)
I see it. Its at the back left side of the block. That hole is supposed to drain any liquid that builds up in the valley between the left and right cylinder banks. If engine oil is coming out of that hole you probably have a bad head gasket.
Antifreeze or gas might also be coming out of that hole if those systems have a leak.
roncallo is online now
