Steering Wheel Replacement - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 01-10-2018, 08:44 AM
okyoureabeast's Avatar
Date registered: Mar 2017
Vehicle: 1984 380SL
Quoted: 638 Post(s)
Originally Posted by Franco380 View Post
Blue unless you never want it to come off. Seriously though you think it will come off then the splines will bresk loose and you'll find it loose in your lap? I'd think you'll be ok giving in a good healthy tightening. Thanks.
I wouldn't use any locktite. I just put mine in with 2 grunts of my small ratchet and call it a day. Still hasn't come out on me yet.
okyoureabeast is offline
post #12 of 12 (permalink) Old 01-10-2018, 07:38 PM
PanzerPuff's Avatar
Date registered: Dec 2013
Vehicle: 1987 560SL
Quoted: 870 Post(s)
Good advice, but for full disclosure, the MB manual says to use microencapsulated threads, that I assume means thread lock compound when reinstalling the steering wheel. Two grunts on that screw is 80 newton meters, pretty damn tight. BTW, even if that screw falls out you still have steering if you keep forward pressure on the wheel. Just don't pull it off the splines.
PanzerPuff is offline
