Mercedes-Benz Forum (https://www.benzworld.org/forums/)
-   R/C107 SL/SLC Class (https://www.benzworld.org/forums/r-c107-sl-slc-class/)
-   -   just installed original bosch wiper refills, here`s how (https://www.benzworld.org/forums/r-c107-sl-slc-class/2881713-just-installed-original-bosch-wiper-refills.html)
kennedy 09-18-2017 11:11 AM
in my 88 560sl with the original stainless steel wipers.
1 buy 19 inch refills bosch number z-367
2. use a needle nose pliers and spread the end tab that is in the short slot on the old refill, the other end is longer
3. slide the old refill out
4. reuse the 2 long metal inserts out of the old refills
5. slide the new refill on while holding the metal inserts inplace(you need 3 hands)
6. use the needle nose pliers to squeeze the tab back into the small slot on the refill.
ten minute job and looks a lot better then the new after market wipers, no pics, but once you have the new refills you can figure it out
ChiefRider 09-18-2017 03:02 PM
I did this years ago in my own 560. Probably should put new refills in my 280's, but they never see rain!
lrg51 09-18-2017 04:25 PM
Don't ever throw those metal inserts away! Voice of experience...:eek
slik560 09-25-2017 06:52 AM
Once again, this forum has spared me some anguish for that time in the near future when I will have to replace the wiper inserts. ;) Note to self: keep the inserts!!
lrg51 04-18-2019 09:49 AM
Kennedy,
I am having trouble locating a supplier for the rubber wiper blade. BOSCH Tech Siupport says they no longer make the rubber-only insert. Did you buy a BOSCH blade refil and modify it to fit the original steel blade holder? I appreciate your advice.
nobby 04-18-2019 06:44 PM
Originally Posted by lrg51 (Post 17760380)
Kennedy,
Have you tried an MB dealer?
That's where I got mine, not long ago.
lrg51 04-18-2019 07:04 PM
Thanks for the reply Nobby.
I did... They could not locate the rubber blade insert to fit the OEM wipers. Wanted to sell me a refill blade. So far, I'm not interested in a refill. I even drove the car to the dealership for their reference. Got a lot of stares... Maybe I need to cross the boarder? LOL!!
I'll keep looking or maybe try a different MB dealer.
rick 04-18-2019 09:32 PM
Have you looked here?
https://www.ecstuning.com/Search/SiteSearch/0008241827/
sh0rtlife 04-18-2019 10:11 PM
its been a while but ive been doing this kind of replacement over the years on everything...ever try getting new blades for a 58 ford? or a 58 lloyd? let alone the rest of the 70s stuff i have..i WISH i still had the OEM ends on my 83 gtv6 cause NOTHING stays on that car long...they either blow off or wobble about
the trick is to just go into a parts store and look (yes actualy lay eyes on) thru the blades and figure out which ones you can re-use your bits on...the blade edges themselves have never changed, sometimes youll need to use the plastic "sleeve" sides with the new blade slipped into your old setup, other times you use your old metal, never mind the length as you can always just cut to fit.....my 58 ford and lloyd use very short blades so one 20inch will make me a pair of 10s
i always had the best luck "fitment" wise with the trico...sure they arnt as good as the bosch but fitment wise i always had the best luck
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
