Thumping sound from back on uneven road surfaces - Page 2 - Mercedes-Benz Forum
post #11 of 18 (permalink) Old 05-09-2019, 01:52 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 106 Post(s)
TaDa.
rowdie is offline
post #12 of 18 (permalink) Old 05-09-2019, 02:05 PM
Don Becker's Avatar
Date registered: Sep 2014
Vehicle: 1981 380SL
Quoted: 8 Post(s)
Thanks again, rowdie. I am confident-enough that is the problem that I have already ordered the part and a spare. I'm betting it fell off when that front top-to-windshield seal/weatherstrip was replaced and it was not noticed. This way, when we do remove the hardtop for the season, I'll have a new one in hand! RE my quick-reply up above, to JS5D, it still (to me) seems a little odd the rear side top locks don't hold it down enough to prevent this . . . . but, still I am pretty confident this is the culprit . . . . . Don
Don Becker is offline
post #13 of 18 (permalink) Old 05-09-2019, 04:10 PM Thread Starter
JS5D's Avatar
Date registered: Dec 2016
Vehicle: 1983 380SL
Quoted: 85 Post(s)
Why yes - I don't have a rubber washer for sure. Excellent, will order one now and fit asap. Thanks very much!
Don Becker likes this.
JS5D is offline
post #14 of 18 (permalink) Old 05-10-2019, 05:03 AM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2371 Post(s)
Originally Posted by JS5D View Post
Hello. For an update, I have not yet found the cause, but suspect what it is the weight of the hard top and some flexibility in the mounting/seals. When I release the rear stud type clamp (rotate the lever on the side) the rear comes up a little and thumping goes away. My theory is now that the thumping is the hard top moving down (dt weight and compression of the seal) then it jumps up and it is the securing stud stopping the upward motion that makes the noise (or at least that is the theory).
It's your car's way of saying:
"Get that fucking top off of me and get some fresh air!"
Originally Posted by nobby View Post
Donítí ever wrestle with a pig. Youíll both get dirty, but the pig will enjoy it.
Originally Posted by rocky raccoon View Post
Soldier on Old Chap. The Pig is you and you are the Pig.
nobby is offline
post #15 of 18 (permalink) Old 05-23-2019, 02:56 PM Thread Starter
JS5D's Avatar
Vehicle: 1983 380SL
Quoted: 85 Post(s)
Originally Posted by rowdie View Post
TaDa.
Hi Rowdie,
Following your excellent advice (and of course also from Nobby) I ordered the offending part for Europarts.com for about $25 (because they had it in genuine MB) and it just arrived.
Interestingly this is a lot more sophisticated than I expected. It has some sort of build in seal lip - almost like somebody has put a lot of thought into this. I attached an image of the item (hope it works).
so for the installation from the picture I presume the orientation is such that the seal wedges into the car, like pointing down if you see what I mean?
Regards. JS5D
JS5D is offline
post #16 of 18 (permalink) Old 05-23-2019, 03:44 PM
rowdie's Avatar
Quoted: 106 Post(s)
What is the part number for that? Should be 107 997 17 81 Site supporting vendor mboemparts has it for $12.58 107 997 17 81. If you go to the Supporting Vendors page of BenzWorld.org I think they have a code for free shipping in some instances.
rowdie is offline
post #17 of 18 (permalink) Old 05-23-2019, 05:33 PM
MBGraham's Avatar
Date registered: Oct 2006
Vehicle: '72 350SL, '85 300D, '98 E320, '19 Subaru Outback (sold '14 GLK250)
Quoted: 20 Post(s)
Hi Rowdie,
I checked that number on EPC and it seems same is used for 350/450/380 SLs. Checked my hardtop and it doesn't have one! Never noticed a problem, but HT seldom goes on.
In same section, I saw another item 1079973281. Also a grommet. It's shown next to the heated rear window pane. Maybe where cables come through?
1972 350SL 4.5L, E320, 300D, Outback 2.5 - near Kingston, Ontario
MBGraham is offline
post #18 of 18 (permalink) Old 05-24-2019, 08:26 AM Thread Starter
JS5D's Avatar
Vehicle: 1983 380SL
Quoted: 85 Post(s)
yes P/N 107 997 17 81, which if you do a google search gives various forms of grommets, nothing as elaborate as the one I received. It was $16.75 with some shipping cost. Will check out MBOEMparts next time thanks.
JS5D is offline
