450 SL 1974: Heater always on. - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 06-24-2017, 08:16 AM Thread Starter
Date registered: Aug 2009
Vehicle: W107 W113
Quoted: 100 Post(s)
Hello,
could someone point out where the heater valve is for a 450 SL, the controls inside the car seem to be inoperative and there is hot air blowing in...
It's summer here and it's very hot now, if I could temporarily just close off the valve it would be great.
Thank you
Sent from my EVA-L19 using Tapatalk
S320L1999 is offline
post #2 of 13 (permalink) Old 06-25-2017, 06:42 AM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 848 Post(s)
Try the R107 forum
rumb is offline
post #3 of 13 (permalink) Old 06-25-2017, 08:06 AM
Fonzi's Avatar
Date registered: Jun 2010
Vehicle: 450slc5.0cab 280sl5sp 280se4.5 500seAMG +250seStkW108 350sl4spdX3 500secEuro
Quoted: 2358 Post(s)
The failure mode for the vacuum actuated valve on the firewall is for the heat to be on. If you can't figure out how to get it to stay off, you won't be the first person the put a plumbing valve in the hose. :-)
Moving to r/c107 forum
Fonzi is offline
post #4 of 13 (permalink) Old 06-25-2017, 12:11 PM
Ianwright40's Avatar
Date registered: Dec 2015
Vehicle: 1973 450SL, 1999 c230
Quoted: 320 Post(s)
Originally Posted by S320L1999 View Post
Hello,
Thank you
If the control of the 74 is the same as my 73.... The slider on the far right has a micro-switch which operates at the very end of the downward travel of that slider. If that adjustment is out that could cause your problem. If I recall, removing the glove box and the trim panel under the dash will give you access to that slider and you should be able to manually activate the switch or bypass it too test.
Ianwright40 is offline
post #5 of 13 (permalink) Old 06-25-2017, 02:54 PM
Date registered: Apr 2006
Vehicle: 1983 380SL, 2000 S430, 1991 420SEL (retired) - RHD
Quoted: 397 Post(s)
The quick and dirty way is to simply block off the hot water inlet hose. Either plug it or squeeze it. No negative side effects. Then you can trouble shoot.
Edit
It only has low pressure but you need to make sure the plug is well secured
Aussiemerc is offline
post #6 of 13 (permalink) Old 06-27-2017, 03:10 PM Thread Starter
Vehicle: W107 W113
Quoted: 100 Post(s)
Great, thank you. I've opted for keeping the valve shut off using a zip tie.
Thanks again
Currumbin SL likes this.
post #7 of 13 (permalink) Old 06-27-2017, 04:18 PM
MBGraham's Avatar
Date registered: Oct 2006
Vehicle: '72 350SL, '85 300D, '98 E320, '19 Subaru Outback (sold '14 GLK250)
Quoted: 20 Post(s)
If you go to Startekinfo, there is a section under 107 workshop manual that describes the climate control system.
https://www.startekinfo.com/StarTek/.../74450sl.html#
MBGraham is offline
post #8 of 13 (permalink) Old 06-28-2017, 05:53 PM
masand68's Avatar
Date registered: Mar 2012
Vehicle: '72 450SL, 107.044-12-000422
Quoted: 49 Post(s)
I believe both outboard sliders have micro switches (my 72 does). If either outboard lever is anywhere other than full down position, the vacuum actuator for the valve is commanded open.
Sent from my SM-T350 using Tapatalk
Ianwright40 likes this.
masand68 is offline
post #9 of 13 (permalink) Old 07-13-2019, 09:19 AM
Date registered: Jul 2019
Vehicle: 1972 350 SL
Edit
I am glad I saw this thread. My 1972 350SL is having the same issue. Just throws heat, mostly at the feet, especially when moving. The levers don't work and I am not interested in fixing it in any complicated way -- its a summer fling car, driven only with the top off. I don't need AC, or any airflow whatsoever to the cabin. So... quick and dirty sounds good to me... but can you help me identify the "hot water inlet hose" so I can pinch it off?
eratosthaenes is offline
post #10 of 13 (permalink) Old 07-13-2019, 11:21 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 111 Post(s)
If yours is original it connects to the metal valve pictured. You can manually close the valve.
rowdie is offline
