1983 280sl fuel pump relay HELP!!! - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 04-13-2017, 10:04 PM Thread Starter
Date registered: Dec 2014
Vehicle: 1980 280slc 4 speed
Quoted: 34 Post(s)
Hi,
Took my cousins '83 280SL on a drive today and after driving for about an hour the car just died. At first I thought maybe I ran out of gas but that wasnt the case. From what I can find online it seems to be the fuel pump relay. I have a 1980 280SLC I was thinking about swapping relays to see if that is the solution however I cant figure out where the relay is one either car. If anyone can help me out that would be great!!!
Mark Mollica is offline
post #2 of 16 (permalink) Old 04-14-2017, 05:06 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 111 Post(s)
On the '83 the fuel pump relay is behind the glove box. Remove the liner and look for a silver box on the right.
Not sure about the '80. I think it is the top left relay of the relays above the fuses.
rowdie is offline
post #3 of 16 (permalink) Old 04-15-2017, 05:43 AM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2388 Post(s)
On my 83 280 SL....the FPR is above the fuse box....you will have to remove the panel to get to it.
It is a BLACK relay part number 001 545 43 05.
Originally Posted by nobby View Post
Donítí ever wrestle with a pig. Youíll both get dirty, but the pig will enjoy it.
Originally Posted by rocky raccoon View Post
Soldier on Old Chap. The Pig is you and you are the Pig.
nobby is offline
post #4 of 16 (permalink) Old 04-15-2017, 06:05 AM
rowdie's Avatar
Quoted: 111 Post(s)
Thanks Nobby. That's what I get for assuming it would be the same as my '84 500SL and the North America model 380SL.
okyoureabeast likes this.
rowdie is offline
post #5 of 16 (permalink) Old 04-15-2017, 06:37 AM
Bob's Your Uncle!
nobby's Avatar
Meh.
There are more than one place to look for relays across the models......more information is better than less.
nobby is offline
post #6 of 16 (permalink) Old 04-16-2017, 12:54 PM Thread Starter
Quoted: 34 Post(s)
Meh.
It was behind the glove box. Same part number as what you sent. Still can't figure out what's wrong. I have a test light and tested the wires going to the fuel pump and the fuel pump is getting power so I assume the relay is working then. My only other guess is the fuel pump we out. As mentioned the car was driving fine and just died. It has spark so it must be a fuel issue. The car did sit for a number of years. Any other ideas what it might be or is it most likely a bad fuel pump?
post #7 of 16 (permalink) Old 04-17-2017, 04:43 PM
rowdie's Avatar
Quoted: 111 Post(s)
Try applying 12v to the pump terminals.
rowdie is offline
post #8 of 16 (permalink) Old 04-17-2017, 05:00 PM
Date registered: Jul 2013
Vehicle: 380SL, Jag F-type
Quoted: 300 Post(s)
Make sure NOT TO LEAN ON THE GLOVE BOX LATCH while working there.
SinSL is offline
post #9 of 16 (permalink) Old 06-17-2019, 12:34 PM
Date registered: Jun 2019
Quoted: 2 Post(s)
Mark appreciate this is a very old thread but did you eventually find the cause?
I seems to have the same issue on a 83 280sl.
I have spark to the cylinders
FPR seems fine
Fuel is delivered to the injectors
Car turns over but wont fire.
Neltec is online now
post #10 of 16 (permalink) Old 06-18-2019, 05:47 AM
Weather Man's Avatar
Date registered: Dec 2008
Vehicle: 1984 380SL
Quoted: 298 Post(s)
I wondered about this when my FPR went out. What else could cause that? I came up with crank position sensor -- if it thinks it isn't turning it shuts down the pumps. The new relay seemed to fix it....
Weather Man is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Neltec
