Shock Absorbers - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 04-13-2017, 09:23 AM Thread Starter
terry2shot's Avatar
Date registered: May 2015
Vehicle: 1989 MB 560SL
Quoted: 2 Post(s)
Shock Absorbers
I want to change out the shocks on my 1989 560SL. I cant seem to find front and rear shocks from the same manufacture. Is this the case or is there one manufacture that build both?
terry2shot is offline
post #2 of 22 (permalink) Old 04-13-2017, 09:54 AM
Hillingdoner's Avatar
Date registered: Oct 2015
Vehicle: 1977 450 sl
Quoted: 148 Post(s)
Bilstein makes front and rear.
Hillingdoner is offline
post #3 of 22 (permalink) Old 04-13-2017, 09:58 AM
Quoted: 148 Post(s)
Just popped on RockAuto to look at numbers. Notes without self leveling suspensions.
Listing B4 as OE replacment
Front: 24005241 {#084398, 1073200230, F4B360524H0} B4 OE Replacement
Rear: 24005111 {Click Info Button for Alternate/OEM Part Numbers
Many on here using Bilstein and loving them.
You might look at KYB too although at least RockAuto is just listing upgraded rears for KYB. Of course, RockAuto is only one source (and maybe not the best who knows). Just happens to be the one I looked at.
Now if you are meaning that you are not finding the same "number" for front and rear then you won't. Different part numbers.
post #4 of 22 (permalink) Old 04-13-2017, 10:38 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 109 Post(s)
Here are the Mercedes part numbers. Google them.
Rear 126 320 09 31
Front 107 320 02 30
Bilstein and Sachs both make front and rear.
rowdie is offline
post #5 of 22 (permalink) Old 04-14-2017, 01:29 AM
CaptHarv's Avatar
Date registered: Sep 2016
Vehicle: 1988 560SL
Quoted: 43 Post(s)
Rear 126 320 09 31
Front 107 320 02 30
rowdie..have a question for you, and I do respect your opinion....I had both front and rear shocks replaced last week on my '88 560SL at my local stealership...my invoice shows what you found for fronts 107 320 02 30... for rears, my invoice shows 126 326 16 00. I googled both part numbers for the rears...mine, and what you found 126 320 09 31, and both show as part number being correct for a 560SL....could they be year specific ?... I didn't think so, but I'm a bit confused and thought you could explain....thanks.....btw, I don't have current access to EPC to see if there's a difference in PN's for rear shocks '86-'89...
CaptHarv is offline
post #6 of 22 (permalink) Old 04-14-2017, 05:47 AM
rowdie's Avatar
Quoted: 109 Post(s)
Those are the current part numbers in the EPC.
The EPC does not show part number 126 320 16 00.
rowdie is offline
post #7 of 22 (permalink) Old 04-14-2017, 06:01 AM
CaptHarv's Avatar
Vehicle: 1988 560SL
Quoted: 43 Post(s)
The part that I had the question about was 126 326 16 00.....not 126 320 16 00
CaptHarv is offline
post #8 of 22 (permalink) Old 04-14-2017, 06:59 AM
rowdie's Avatar
Quoted: 109 Post(s)
Oops. Nothing on 126 326 16 00 either. Google says it is valid but no model info.
rowdie is offline
post #9 of 22 (permalink) Old 04-14-2017, 07:50 AM
CaptHarv's Avatar
Vehicle: 1988 560SL
Quoted: 43 Post(s)
Thanks for checking rowdie....
CaptHarv is offline
post #10 of 22 (permalink) Old 04-15-2017, 06:41 AM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2387 Post(s)
Could be Comforts versus Heavy Duty?
WAG
Originally Posted by nobby View Post
Donítí ever wrestle with a pig. Youíll both get dirty, but the pig will enjoy it.
Originally Posted by rocky raccoon View Post
Soldier on Old Chap. The Pig is you and you are the Pig.
nobby is offline
