A few stupid questions - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 02-09-2017, 01:51 PM
MBGraham's Avatar
Date registered: Oct 2006
Vehicle: '72 350SL, '85 300D, '98 E320, '19 Subaru Outback (sold '14 GLK250)
Quoted: 20 Post(s)
Originally Posted by stradivari1689 View Post
Slams a bit when going into drive from park (but not so much into reverse), am hoping it has to do with a high cold idle (1500-1700 in park), otherwise it shifts fine whilst driving.
That is high. Engine would normally surge once rpms go above ~1500rpm (ECU cuts off fuel then turns it on again at just under 900rpm). You can adjust the rpm down a bit using the idle screw just next to the AAV front of engine. When everything (especially AAV) is working right, cold idle will be quite a bit lower - maybe 1200rpm in summer?
1972 350SL 4.5L, E320, 300D, Outback 2.5 - near Kingston, Ontario
MBGraham is offline
post #12 of 12 (permalink) Old 02-09-2017, 02:01 PM Thread Starter
Date registered: Jun 2007
Vehicle: Ex 202.028, 124.028, 107.045 (with 117.967), 129.067; now 163.154, 203.764, 129.066
Quoted: 45 Post(s)
PO only had bits and pieces of the service history, all recent, although he's owned the car since around 1987. One curious item from a few months ago after I'd initially looked at the car was a reference to a "CIS unit with cracks and tape" that may be contributing to the idle problem. I'm interpreting that as a mis-naming of the D-jet ECU, although I haven't looked under the glove box to verify the physical condition of that unit.
I do see the AAV and idle screw very clearly and will try fiddling with those as well.
stradivari1689 is offline
