Switched Fog Lights to LED - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 07-31-2015, 10:30 PM Thread Starter
bigsky's Avatar
Date registered: Sep 2013
Vehicle: 1984 280sl 5spd, 02 E320 4matic, 79&79 450sl part-out, 78,79,81,83 300CD, 79 280CE
Quoted: 487 Post(s)
My original fog lights were in poor shape, was going to run car with no lower fog lights at all. Found, front of car with spoiler just did not look right without fog lights. Never have been happy with the light output of factory fog lights. Ordered a set of 4" x 7" 36W Cree LED spot lights. They had mounting brackets that I could run a 1/4" rod through. This allowed me to drill mounting bracket, and install set screws, for vertical adjustment. Then took factory fog light mounting bracket, and cut off the ends, with mounting holes drilled in them, and welded the ends to my 1/4" rod. This gave me horizontal adjustment, and allowed me to use all factory bolts, and mounting holes in bumper. Really surprised at the amount of light that these LED lights put out.
Pic #1 : LED light compared to factory
Pic #2 : 1/4" rod ran through mounting brackets, factory hardware welded on to rod. Horizontal adj. set screws drilled.
Pic #3 , #4 , #5 : Lights mounted.
Pic #6 : Hi Beam headlights
Pic #7 : Fog lights only
Pic #8 : Hi beam headlights, and fog lights
Like how the hi beam headlights, and the fog lights on together light up the road. Is it possible to wire fog lights into my hi beams directly? Or is an extra 36W to much without wiring a relay into the hi beams?
ID:	1554665   Click image for larger version
ID:	1554673   Click image for larger version
ID:	1554681   Click image for larger version
ID:	1554689   Click image for larger version
ID:	1554705   Click image for larger version
ID:	1554713   Click image for larger version
cwmoser likes this.
bigsky is offline
post #2 of 15 (permalink) Old 08-01-2015, 02:14 AM
Djenka018's Avatar
Date registered: Jan 2005
Vehicle: '80 450SLC Afro RHD Ikonengold
Quoted: 119 Post(s)
Seldom any replacement-modification tickles my fancy.
I do not like the look of the led's on the 30+yo car but that's only my taste and nothing more. Your mod integrates new function into original design quite well.
I think you may be confusing the function of the spot lights with fog lights.
My fog lights are making a wide horisontal line beam and the idea is to control scatter in order to minimise the reflection from the vapour droplets (unlike high beam). Hardly any usable light... until you indeed drive in the thick fog.
But what I find interesting is the headlights mod you did.
It resembles that done for 126 and 124 and it is my favourite of all DOT afterthoughts
Vitamin C for SL... the SLC
Djenka018 is offline
post #3 of 15 (permalink) Old 08-01-2015, 03:25 AM
cwmoser's Avatar
Date registered: May 2004
Vehicle: 1983 380SL, ivory/dk brown, 44k miles, dual roller timing chain. 1986 560SL, red/white, 184K mile.
Quoted: 1718 Post(s)
I like.
I like creative thinking to make the original better or to fix what is broken.
BTW, have you used LEDs for your interior lighting? LEDs really illuminate the interior.
Walt Williams likes this.
Carl
"You have chosen to drive a MERCEDES-BENZ, a car in whose construction and production we have taken great pains because we believe that quality is not a matter of chance." -- page 3, Owners Manual 380SL
Timing Chain, Subframe, wiring harness, Climate Control, Rust prevention, etc.
cwmoser is offline
post #4 of 15 (permalink) Old 08-01-2015, 05:24 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 106 Post(s)
I agree. This defeats the function of the fog lights. Basically it adds extra driving lights.
rowdie is offline
post #5 of 15 (permalink) Old 08-01-2015, 06:49 AM
reno4u2's Avatar
Date registered: Dec 2009
Vehicle: 1988 560SL (California Model)
Quoted: 827 Post(s)
They sure do!
reno4u2 is offline
post #6 of 15 (permalink) Old 08-01-2015, 07:43 AM
Fonzi's Avatar
Date registered: Jun 2010
Vehicle: 450slc5.0cab 280sl5sp 280se4.5 500seAMG +250seStkW108 350sl4spdX3 500secEuro
Quoted: 2316 Post(s)
I have to confess to using the fogs on my 1985 280sl like high beams in non-foggy weather. The wide light is nice. I think they might be pointed a little high. They do see to work a bit like high beams lighting up the trees as I head down a dark country road. I definitely like having them available, whatever they are for.
Just looking at all the bugs on the front of bigsky's car, you can tell he is doing a good bit of driving at night.
My signature:
If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #7 of 15 (permalink) Old 08-01-2015, 09:15 AM Thread Starter
bigsky's Avatar
Quoted: 487 Post(s)
The only time we get fog up here is in the winter, when car is in hibernation mode. In the 2 years I have owned car, I tried fog lights once. Was so un-impressed with light output, never used again.
No, not yet, maybe this winter. Not to worried about interior, lots of dust, mud here. Have been really impressed with new LED technology. First LED lights I have ever used were the LED shop lights, installed in shop before painting. They worked so good, thought I would give these a try. They really light up the road. Will now actually use these lights.
One of the problems with factory fog lights, is that they had no easy vertical adjustment. These lights shoot a beam just a little wider then the hi beams, and just a little bit farther. The light seems more "white" then the hi beams. Really lighting up reflective road signs, and hopefully deer eyes
All bugs are from daytime driving, last night was the first time I used lights all summer Gets up to 95F in daytime but cools to low 50's at night.
My main question is: Can I now wire these LED lights directly to my Hi beam circuit, or will the extra 36 watts be to much for the fuse/dimmer switch/wiring?? I would completely by pass the fog light switch.
bigsky is offline
post #8 of 15 (permalink) Old 08-01-2015, 06:19 PM
Djenka018's Avatar
Quoted: 119 Post(s)
36W is not much from safety perspective but it will add up on already loaded switches and a further voltage drop on them will reduce the output from the high beam.
You are probably better off running a 40A relay to feed both the globes and LED's. This way a fresh wire from the battery (and a 20A fuse) via the relay will provide minimum voltage drop. I would think AWG14 is minimum thickness of the wire, AWG11 being the optimal.
FYI, on a normal globe at 14.2V (nominal alternator voltage) you get max light output in kLux.
At 11V on the globe the light output is probably more than 30% reduced.
post #9 of 15 (permalink) Old 08-03-2015, 12:12 AM Thread Starter
bigsky's Avatar
Quoted: 487 Post(s)
Just spent last couple of hours aligning and testing new LED lights. Using stock mounting hardware from original fog lights made alignment easy. Really impressed with the amount/quality of light that these LED's put out. wired LED lights up with quick disconnect connectors so that I can easily wire lights to either come on with fog light switch, or hi beam switch. Running on hi beam did not seem to over work any of the connected components. Testing on a 50 mile drive, with LED lights connected to hi beams, none of the on-coming cars seemed bothered by my having the LEDs on. The only problem is that after running hi beam/LEDs, then dimming for on-coming traffic the dims look dingy, compared to the "whiter light the LEDs put out". Will get some whiter lighted H4 bulbs to see if they will work better on dim.
bigsky is offline
post #10 of 15 (permalink) Old 02-15-2016, 04:43 PM Thread Starter
bigsky's Avatar
Quoted: 487 Post(s)
Update, Installed a couple sets of H4 LED hi/lo beam lights before finding a set that works good, and I liked. Using the W123 as a test platform.
I like the way that the LED fog lights lit up the road. Only ran them on hi beam. Whenever I had to dim to low, the light from the halogens seemed "dirty" . The halogen H4 were Sylvania Silver Stars.
The LED H4 lights I used are rated at 4800 lumen, 40W, hi/lo beams, 6000K. This set works good because they do not use a big cooling fan on the back. They also come with a plate that fits into the H4 mounting slots. I glued that plate into the H4 bulb slots, and the LED lamps twist lock into that plate. Simple
Pic 1: LED H4 set I used
Pic 2: Halogen H4 on bright, look really "dingy" compared to LED fog lights
Pic 3: Lights on dim, drivers side LED, Passenger side halogen
Pic 4: Led H4 on hi, with LED fogs
Running the LED H4's on the W123 I have only found one problem. The LED lights do not put out any heat. When I was driving in a snow storm the lights just covered over with snow, and ice. Not a problem for me because I do not plan on driving any of my rear wheel drive MB's in snow, and ice. Just a caution to others.
ID:	1780762   Click image for larger version
ID:	1780770   Click image for larger version
ID:	1780778   Click image for larger version
bigsky is offline
