1984 280SL fuel distributor hose part number - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 07-24-2015, 08:39 AM Thread Starter
Date registered: Jul 2015
Vehicle: 1984 280SL
Quoted: 5 Post(s)
I have a 1984 280SL - the two rubber coated plastic fuel lines that attach to the top of the fuel distributor via a 12mm banjo fitting need replacing and I'm having trouble finding a part number to order or a vendor. The lines are a semi ridid plastic and they push onto a barbed banjo fitting - the rigid plastic is covered with a rubber outer protective sleeve. the rubber is cracked thought I should replace the hoses. I could use just the hose material if it's available but would take a complete assembly if that's all that's around
does someone have a parts reference catalog that could give me the OEM Mercedes part numbers for these two hoses at least then the retailers can look for a cross reference - most don't have a 280SL in their parts catalog...
DM914 is offline
post #2 of 10 (permalink) Old 07-24-2015, 09:07 AM
daryn's Avatar
Date registered: Nov 2004
Vehicle: 1978 280slc
Quoted: 54 Post(s)
Weird, i would pull whatever you have off and replace it with fuel injection rated rubber line. It should uses barbed fitting. You could almost remove it in situ, so you won't have to replace the crush washers. There was a change in fd design so mine doesn't have any flex line like that.
edit, I wonder if those are vacuum lines, no way would you run fuel through hard plastic line. Hopefully someone with knowledge of the later generation FD will pipe in.
daryn is offline
post #3 of 10 (permalink) Old 07-24-2015, 10:02 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 106 Post(s)
Did your 280SL spend time in California? Those hoses are not shown in the MB Electronic Parts Catalog (EPC). Here is my 1984 280SL.
ID:	1545065   Click image for larger version
ID:	1545073   Click image for larger version
rowdie is offline
post #4 of 10 (permalink) Old 07-24-2015, 10:27 AM Thread Starter
Vehicle: 1984 280SL
Quoted: 5 Post(s)
California - no that I'm aware of - was imported into MINN and then spent most of it's time Florida before coming to Canada about 11 years ago. I bought off the owner who imported from FL
DM914 is offline
post #5 of 10 (permalink) Old 07-24-2015, 11:02 AM
rowdie's Avatar
Quoted: 106 Post(s)
I asked because I have seen 280SL models that spent time in CA adapted with emission control equipment. I know of more than one that had a frequency valve, O2 sensor and catalytic converter added. The even had some sort of aftermarket lambda controller. One with a frequency valve had a banjo fitting with line like yours in the same place but it only had one banjo fitting. Does one of those lines lead to what looks like an electronic fuel injector? I will see if I can find a picture.
rowdie is offline
post #6 of 10 (permalink) Old 07-24-2015, 01:39 PM
bigsky's Avatar
Date registered: Sep 2013
Vehicle: 1984 280sl 5spd, 02 E320 4matic, 79&79 450sl part-out, 78,79,81,83 300CD, 79 280CE
Quoted: 487 Post(s)
A couple of Pics of my 84 Different than yours, way different than Rowdies. Looks like line just re-circulates fuel?
Originally Posted by rowdie View Post
I asked because I have seen 280SL models that spent time in CA adaped with emission control equipment. I no of more than one that had a frequency valve, O2 sensor and catalytic converter added. The even had some sort of aftermarket lambda controller. One with a frequency valve had a banjo fitting with line like yours in the same place but it only had one banjo fitting. Does one of those lines lead to what looks like an electronic fuel injector? I will see if I can find a picture.
My Car has at one point been CA smogged, but had no 02 sensor, catalytic converter, or lambda.
ID:	1545329   Click image for larger version
ID:	1545337   Click image for larger version
bigsky is offline
post #7 of 10 (permalink) Old 07-24-2015, 01:55 PM
rowdie's Avatar
Quoted: 106 Post(s)
That piece with yellow connector is a frequency valve. Not stock.
rowdie is offline
post #8 of 10 (permalink) Old 07-24-2015, 02:45 PM
bigsky's Avatar
Quoted: 487 Post(s)
It does not plug into anything. Checked entire engine bay, and could not find any wires, or connections for this frequency valve. Not sure how long ago car was smogged in CA, Montana does not have any of that BS
bigsky is offline
post #9 of 10 (permalink) Old 07-24-2015, 03:40 PM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2359 Post(s)
It's all useless garbage added to satisfy some State's rules. I would eliminate the whole mess.
You probably also have a CAT...which is also not stock.
Originally Posted by nobby View Post
Donítí ever wrestle with a pig. Youíll both get dirty, but the pig will enjoy it.
Originally Posted by rocky raccoon View Post
Soldier on Old Chap. The Pig is you and you are the Pig.
nobby is offline
post #10 of 10 (permalink) Old 07-24-2015, 07:40 PM Thread Starter
Vehicle: 1984 280SL
Quoted: 5 Post(s)
Looking for a transmission pad / plug and gasket
since it has fuel running through it I'll dig an look to see where it's coming from. maybe I can block it off or remove. No CAT on the car or O2 sensor - their is what looks like an EGR valve on top of the exhaust manifold it has a vacuum line fitting but no hose... I'll take a picture and post maybe some one knows what it is.
I'm pretty mechanically inclined but don't know a lot about these W107 cars.
I have another question - looking for replacement transmission pan, the drain plug and the gasket. anybody know the MB part numbers so I can source them somewhere. Car is an automatic.
DM914 is offline
