Convertible Top Lid Cover Question - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 12-28-2014, 06:27 PM Thread Starter
bleverman's Avatar
Date registered: Mar 2013
Vehicle: 1987 Mercedes 560SL
Quoted: 26 Post(s)
I'm redoing the vinyl on my lid cover and am missing one of the round washer clip looking things. What are these things called? I'm trying to locate one and can't seem to find it.
bleverman is offline
post #2 of 22 (permalink) Old 12-28-2014, 06:32 PM
One of the BW Old Guard
Ears's Avatar
Date registered: Aug 2004
Vehicle: 1997 SL500- 40th Anniversary
Quoted: 514 Post(s)
I seem to remember them called "speed nuts" from way back in my youth...
Best Regards...
RM Smith
Where is it again that we are going... And why are we in a handbasket?
Ears is offline
post #3 of 22 (permalink) Old 12-28-2014, 07:03 PM
Date registered: Apr 2013
Vehicle: 1980 Mercedes 450SL, 1975 Mercedes 450SEL
Quoted: 12 Post(s)
I replaced my vinyl this past summer. I don't remember seeing those fastners there. However, they are used on my name badge -450sl. (I made a gasket out of a bicycle inner tube for the badge-water was getting in the trunk)
They were hard to get back on, to grip once again after removing. If I ever have to remove one again, I'd buy new ones. They seem like single use parts.
Panzergirl is offline
post #4 of 22 (permalink) Old 12-28-2014, 07:10 PM Thread Starter
bleverman's Avatar
Quoted: 26 Post(s)
"Speed nuts" got me a little closer in my search but can't find these exact ones. I'll call the dealer tomorrow and see if they have them for a reasonable price. If not, I'll make something at the hardware store work. Thanks!
post #5 of 22 (permalink) Old 12-29-2014, 06:20 AM
Vehicle: 1976 450sl
Quoted: 44 Post(s)
we used to call them tinnerman nuts
Encompass1 is offline
post #6 of 22 (permalink) Old 12-29-2014, 06:56 PM
72 350sl's Avatar
Date registered: Aug 2014
Vehicle: 1972 350sl
Quoted: 34 Post(s)
I always knew them as "push nuts". Should be able to find them at a hardware store or Home Depot/Lowes. It won't match the others but would work.
72 350sl is offline
post #7 of 22 (permalink) Old 12-29-2014, 10:46 PM
Premium Member
Droidster's Avatar
Date registered: Nov 2013
Vehicle: 74 450SL 107 044 12 020684 73 280SE 4.5 108 067 12 021470
Quoted: 187 Post(s)
Premium Member
I think they also call them circlips.
These look somewhat close.
http://www.ebay.com/itm/291221494142?rmvSB=true
I'm certain you can find them for less.
Droidster is offline
post #8 of 22 (permalink) Old 07-16-2019, 07:58 AM
Date registered: Oct 2014
Vehicle: 2003 E500 V8, 1988 560SL
Quoted: 23 Post(s)
Hello; I have a question about closing the soft top cover.
I have removed my hard top and the soft top is up. When I close and stow the soft top the passenger side will not stay attached, so it pops up when I drive.
When the top is not stowed and I close the cover ( the soft top is not secured and I do not drive it like this) the cover stays securely attached, I cannot pull up on the passenger side and make it pop out.
What is causing this? Is the soft top not stowed properly so it puts pressure on the cover , causing it to release?
nzvlnr is offline
post #9 of 22 (permalink) Old 07-17-2019, 06:30 AM
Date registered: Apr 2006
Vehicle: 1983 380SL, 2000 S430, 1991 420SEL (retired) - RHD
Quoted: 397 Post(s)
You have to make sure the soft top is pushed down into the well.
Aussiemerc is offline
post #10 of 22 (permalink) Old 07-17-2019, 06:40 AM
Quoted: 23 Post(s)
How far down? The windshield twist locks are not below the compartment storage sides . I have tucked it down, but maybe it is not low enough. How far down is it supposed to sit?
nzvlnr is offline
