Yet another "what is my SL worth..." - Mercedes-Benz Forum
post #1 of 20 (permalink) Old 08-31-2014, 11:45 PM Thread Starter
Date registered: Oct 2013
Vehicle: 1988 560SL, 2005 Subaru OUtback, 2010 Ducati Multistrada 1200
Hello,
Im feeling the market as i just had a kid and am not sure when the 3 of us will be able to enjoy the car. I feel guilty going alone and cant wait for my parents to watch the kid to drive with misses to the beach. Anyway it is 88 560sl with 119k miles. California car, no rust, no accidents, carfax clear. Milage accurate. Paint is good-very good. Everything works. Interior is very good and wood refinished.
I spent 4 months replacing EVERYTHING on this car. It ran good when i bought it but im very anal and cars are a hobby so i did it all!
Suspension fully rebuilt.
Bilstein shocks
New ball joints
Motor new chain, cam sprockets, tensioner, stem seals, all air injection hoses, vacum lines, thermo vacum switches, water pump, water hoses, water tank, radiator, distributor rotor cap, crank oil seals,
Rebuilt the steering pump,
Rebuilt the steering box
Replaced all steering linkages, damper
Replaced transmission hoses
Replaced power steering hoses
Engine mounts and subframe mounts
Sway bar bushings
Transmission mount
Steering coupler
Resealed the diff
Rebuilt both axles (boots were staring to crack)
All rubber in the back, subframe, diff mounts etc
New discs in the front (brembo)
All new brake pads and fluid
New brake hoses
Various vacum switches and valves
New tires with less than 50 miles on them
Hood pad
All new fuel lines, 2 new fuel pumps.
Replaced fuel accumulator.
Replaced fuel pump relay
Removed gas tank and cleaned. Replaced fuel strainer.
All fuel injectors were sonic cleaned and tested.
Transmission was replaced 10k miles ago due to leaks. Still under warranty
Everyitng works and the car is like butter. It is smoother and rides better that my new subaru. I feel bad not driving it but when i do rarely drive it, i am amazed how it runs. It is perfect. Im sure i missed stuff and there is more!
I cant find anything else to do on it so that is part of the problem, i need to stay busy. I have receipts for $7k in parts and pictures of everything. It took 4 months but i had a blast. I either sell it and get a 4 seater or keep in a garage. I took it to alignment shop the mechanics were staring at it and could not believe how clean it was. Guy that did the test ride was amazed and asked if ill sell it.
What do you guys think?
johneracer is offline
post #2 of 20 (permalink) Old 09-01-2014, 03:08 AM
cwmoser's Avatar
Date registered: May 2004
Vehicle: 1983 380SL, ivory/dk brown, 46k miles, dual roller timing chain. 1986 560SL, red/white, 190K mile.
Quoted: 1743 Post(s)
Well ... we here certainly recognize the value of the work you put into this car.
And, it looks like you have thoroughly gone over it and with those receipts
and photos you have the new customer should feel comfortable about the
car mechanically. I assume the AC works, you have both tops, and the soft top
is in great shape. Color and condition also affects the price.
I would find your car very very tempting and would put a premium on
what you have done to it. Its certainly worth more than a similar condition "typical"
Mercedes 560SL. How about posting some pictures?
Carl
"You have chosen to drive a MERCEDES-BENZ, a car in whose construction and production we have taken great pains because we believe that quality is not a matter of chance." -- page 3, Owners Manual 380SL
Timing Chain, Subframe, wiring harness, Climate Control, Rust prevention, etc.
cwmoser is offline
post #3 of 20 (permalink) Old 09-01-2014, 06:37 AM
Fonzi's Avatar
Date registered: Jun 2010
Vehicle: 450slc5.0cab 280sl5sp 280se4.5 500seAMG +250seStkW108 350sl4spdX3 500secEuro
Quoted: 2348 Post(s)
It does sound like you've taken care of the important items, and set the car ready for a decade or so of enjoyment before many of those things need to be done again.
I didn't decide that my family was too big for an SL until we had our third baby. See pics of my 5-point booster seats installed. A rear-facing seat might be near impossible to fit, but those two years go by very quickly. https://www.benzworld.org/forums/r-c1...ump-seats.html
If you plan on having more than two kids, yes, maybe start looking for a bigger car, but until your oldest is about 7+, they can fit back there just fine. I've even had two adults back there on a half-hour, each way drive. It was funny, but not terribly uncomfortable.
I would guess that your car should bring between $8,000 and $12,000, sadly probably closer to the $8000 unless you are really willing to wait out the sale. I think the fact that it has over 100k on the odometer kills it for a more valuable collector potential. What's it really worth? Well, many people would probably buy an $8000 car and have to put those $7000 of parts into it and have $15,000 plus labor into the car. I would think its worth well more than that to the right person. (You?)
I suggest you keep it and enjoy it.
I'm starting to think I should have kept my first one that I sold because I couldn't fit the family of five in it. It's been two years now.
Sent from AutoGuide.com App
My signature:
If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #4 of 20 (permalink) Old 09-01-2014, 12:30 PM
yka
yka's Avatar
Date registered: Dec 2008
Vehicle: US spec MB560SL 1986, Audi A4 and A6, Ford Taunus 1964 17M and 2.0 1975
Quoted: 61 Post(s)
Send a message via Skype™ to yka
Your car sounds very good, some pics would be nice. I really like to look other member's R107 restoration projects.
Yka
"Done is better than perfect."
yka is offline
post #5 of 20 (permalink) Old 09-01-2014, 01:12 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 111 Post(s)
I would rather pay $15-20K for this one than a 30-50 thousand mile garage queen. I too would like pictures. We love seeing great 107s.
rowdie is offline
post #6 of 20 (permalink) Old 09-01-2014, 01:44 PM Thread Starter
Thank everyone. I am on the fence on it. I have benefited from this forum so much that I will happily share pics. Since I have been all over this car if anyone has any issues please feel free to run them by me. I did have a slight acceleration stumble when I bought the car. If you press the pedal lightly car would stumble until pedal was pressed more. It turned out to be idle switch on the throttle was out of rig. Thanks to this forum I quickly found and adjusted it. Here are some pics.
post #7 of 20 (permalink) Old 09-01-2014, 01:56 PM Thread Starter
Apparently I have no clue how to post pics. I am not sure if my computer is blocking the pop ups or what but Ill figure it out.
post #8 of 20 (permalink) Old 09-01-2014, 02:10 PM
cwmoser's Avatar
Click on "Manage Attachments".
Scroll down some to find it.
If you don't see it, then click on "Go Advanced".
Then you can upload 5 pictures per reply - each have their own Browse button.
Carl
Carl
cwmoser is offline
post #9 of 20 (permalink) Old 09-01-2014, 07:39 PM Thread Starter
pics in no particular order
ID:	1108169   Click image for larger version
ID:	1108177   Click image for larger version
ID:	1108185   Click image for larger version
ID:	1108193   Click image for larger version
ID:	1108265   Click image for larger version
ID:	1108273   Click image for larger version
ID:	1108281   Click image for larger version
ID:	1108289   Click image for larger version
post #10 of 20 (permalink) Old 09-01-2014, 07:50 PM Thread Starter
more $$$ gone!
ID:	1108305   Click image for larger version
ID:	1108313   Click image for larger version
ID:	1108321   Click image for larger version
ID:	1108329   Click image for larger version
ID:	1108345   Click image for larger version
ID:	1108353   Click image for larger version
ID:	1108361   Click image for larger version
ID:	1108369   Click image for larger version
