4spd Auto Transmission Horrors? - Mercedes-Benz Forum
post #1 of 19 (permalink) Old 07-28-2014, 09:00 AM Thread Starter
Date registered: Apr 2014
Vehicle: 1984 380SL
Took the '84 380SL out a few days ago. Engine & trans were working perfectly. After fully warmed up, I did two full-throttle rolling acceleration runs, from say 5mph to 60mph, which went fine. Then, about 10mins later, I noticed that it wouldn't upshift past 2nd gear. I drove it the next day, and it initially shifted thru all 4 gears, but as soon as the engine and trans started to warm up, it again became reluctant to upshift. And when I drove it yesterday, doing errands, it was properly getting all 4 gears all afternoon. But then heading home from my last errand, it again quit upshifting out of 2nd gear.
There have been no strange noises, no smoke, or any other clues. When I checked the AT fluid, after each drive, it's level was correct. Any observatons or ideas from you guys? This of course is scaring the crap out of me. Thanks a lot,
David Teachey
David Teachey
Charlotte, NC, USA, Earth
1984 380SL
davidteachey is offline
post #2 of 19 (permalink) Old 07-28-2014, 10:40 AM
jsebastian's Avatar
Date registered: Sep 2011
Vehicle: 1967 250 S (sold) 1986 560 SEC 1987 560 SL
Quoted: 117 Post(s)
Mine was taking a long time to shift out of first, so the experts here said to check the tautness of the Bowden cable, which terminates at the throttle linkage. It should not be too taut or too loose. I had success as mine was too taut.
Experts also say that the trans modulator may be out, but I have no experience with this.
I hope it's not more serious..
Good Repairing,
John
jsebastian is offline
post #3 of 19 (permalink) Old 07-28-2014, 01:34 PM
hchaugli's Avatar
Date registered: Nov 2011
Vehicle: 1985 500SL + 2009 GLK (previous 250, 280SL, 230TE, 430 ML)
Quoted: 91 Post(s)
Has happend twice to my car, but fixed itself after turning off the engine and restart.
Hopefully you only need to adjust the cable.
Check for stuck kickdown solenoid or sticking kickdown switch. (disconnect)
If not, it is likely you have a defective governor assembly or sticking shift valves. Change transmission fluid and filter to be safe.
hchaugli is offline
post #4 of 19 (permalink) Old 07-28-2014, 05:57 PM
Date registered: Dec 2013
Vehicle: 82' 380SL
Check your carpet under the accel. ped. Mine would hangup on the kickdown switch and not let the trans. upshift.
Emory is offline
post #5 of 19 (permalink) Old 08-01-2014, 07:00 AM Thread Starter
Vehicle: 1984 380SL
Thanks for the leads, guys. The kickdown switch is apparently "that black thing" under the accel pedal. Where is the kickdown solenoid located? And do I check and/or adjust the Bowden cable under the hood at the throttle linkage? Thanks again for your time and advice,
David
David Teachey
1984 380SL
post #6 of 19 (permalink) Old 08-01-2014, 07:16 AM
Date registered: Jan 2007
Vehicle: Too Many
Quoted: 162 Post(s)
B2 piston seal failing.....
Current Drivers:
1987 107.048 Stella /// 1987 201.034 Hermann /// 1992 124.051 Gretel /// 2012 212.074 Klaus /// 1991 Range Rover Classic OM606.962/722.6 Oswald
<-Clicky
JoeB is offline
post #7 of 19 (permalink) Old 08-02-2014, 08:15 AM Thread Starter
Vehicle: 1984 380SL
JoeB, my man, what is that and where is that? I'll check it / fix it. Thanks!
David
David Teachey
1984 380SL
post #8 of 19 (permalink) Old 08-02-2014, 01:28 PM
Fonzi's Avatar
Date registered: Jun 2010
Vehicle: 450slc5.0cab 280sl5sp 280se4.5 500seAMG +250seStkW108 350sl4spdX3 500secEuro
Quoted: 2348 Post(s)
Is the 380sl transmission the same as:
- the 500sl trans?
- the 500slc trans?
- the 280sl trans?
- the 560sl trans?
- the 4-speed 350sl trans?
Just curious.
The B2 piston problem sounds like something fotografa had an issue with in his 500slc.
Sent from AutoGuide.com App
My signature:
If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #9 of 19 (permalink) Old 08-02-2014, 04:54 PM
Vehicle: Too Many
Quoted: 162 Post(s)
All 722.3xx transmissions share the same consumable parts
MBZ org has had the writeup on the b2 piston since moses was a child. (when the internet was mailing lists, not forums).
ATSG manual is available online. Suggest you do your research on this, as a 107 will need to have the trans pulled to do the job properly. the risk of dirt ingress is simply too high.
Current Drivers:
<-Clicky
JoeB is offline
post #10 of 19 (permalink) Old 08-02-2014, 06:04 PM
Fonzi's Avatar
I didn't have luck at mbz org and went searching an liked this description I found at http://benzbeat.blogspot.com/2011/06...woes.html?m=1_
Mercedes-Benz Transmission terminology for dummies (722.XXX series transmissions)
I find that a lot of people immediately go to the internet and ask "why is my transmission not working" only to receive a number of seemingly cryptic answers filled with letters, numbers, and foreign terminology. Here is a quick crash-course on the most common terms and references when talking about these transmissions.
B1 - controls 2nd gear. A bad B1 band or piston will make the car shift from first to third.
B2 - most common failure in Mercedes transmissions for years, controls first gear, "shifting into drive"
B3 - reverse gear brake band. Some models of MB transmissions can be adjusted externally to reduce slipping and flaring when engaging reverse, others do not have this feature. If you have an older Mercedes with no reverse, the B3 is the most likely cause. I see this especially in the gas w124s and w201s for some reason, many many cars on the market with no reverse. This requires a trans rebuild to fix.
K1 spring - this is a spring in the valve body that controls the 2nd-to-3rd gear shift. Over time, both the K1 and K2 springs wear out and cause the transmission to flare a bit between shifts. There are "repair kits" available with new springs and seals for the DIYers, not a difficult fix. These springs actually control how the corresponding clutches (called K1 and K2 clutch packs) operate.
K2 spring - similar to K1 controls the 3rd-to-4th shift, along with reverse and overdrive.
"Flaring" - this refers to the RPMs spiking in between shifts under normal driving. This is usually caused by either overly-soft shifts (worn out springs and/or vacuum issues).
"slipping" - This means the car goes in and out of gear, typically creating a jerking motion under acceleration, sometimes also a bad jutter.
Vacuum tuning - The 722.xxx series transmission shifts are controlled by vacuum. A line comes off the engine and plugs into a part called the "vacuum shift modulator" on the passenger side, that will denote how firmly or how softly the car will shift between gears. If you completely disconnect the vacuum line, shifts will be extremely firm (neck-snapping in my diesel!). You can adjust the modulator by turning a plastic tee-connector on the outside of the transmission.
Bowden Cable - This adjusts the shift points. The Bowden cable is attached to the throttle linkage, and basically tells the transmission how far down you're pressing the accelerator...floor it and the shift points will be predictably higher. This typically cable stretches over the years and needs tightening, which can be done on top of the valve cover at a white cable-screw followed by a rubber accordion cover.
Symptoms of a bad B2 piston - If your piston is scratched or scored, it will "catch" on the outer bore of the transmission housing, bushing or seal. This causes intermittent engaging of the forward drive gears. Basically, you can shift into drive, but the second you put any load on the transmission it slips. You won't be going anywhere fast. Many times a sticking B2 will turn into a broken B2 piston since the hydraulic pressure is extremely high, and scoring is only going to get worse (i.e. don't wait to fix it!).
Symptoms of a bad B2 band - this is what I'm dealing with at the moment. The piston itself is fine, no catching, marring, or scoring. However, there is no spring tension on the B2. I am able to push the piston in and it will not push out against my pressure - it should have quite a lot of pressure on it, so much that it is a difficult task to replace the outside cover without some sort of improvised "tool" jammed in between it and the transmission housing (I used a pipe the first time). There is NO drive, no forward motion whatsoever. To expand even more, you will not see a change in RPMs when shifting into drive, and not hear any hydraulic actuation under the car when you shift. Strangely, when mine went, there was no debris in the pan indicating it was a clean break or the debris is stuck somewhere (very possibly the valve body).
My signature:
Fonzi is offline
