Courtesy light switch, how do you reconnect back? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-03-2013, 08:54 AM Thread Starter
an ly's Avatar
Date registered: Jul 2007
Vehicle: 1987 560sl
Quoted: 7 Post(s)
Hello everyone,I have a 87 560sl, my courtesy light did not work so I thought it was the switch so I took out the switch but now I can't find a way to put a new one on since the plugs are not long enough, do I have to take the center console out to put back these switch since I need to push the plug from behind to snap with switch? Any help is appreciated.
an ly is offline
post #2 of 5 (permalink) Old 01-03-2013, 09:26 AM
roncallo's Avatar
Date registered: Apr 2005
Vehicle: 1986 560SL with M120 V12 Engine, 1988 560SL Stock
Quoted: 297 Post(s)
The switch is installed with a tab on the left and right side. Depressing the left side towards the right will release the left side of the switch. The trick is to do this without damaging the burl wood trim. I use a thin feeler blade to protect the wood with a thin 1/8" blade screw driver between the blade and the switch tab. You may need to do this on both sides if the switch.
Once the switch is out the wires can be pulled through and connected.
Other option may be to remove the glove box line and just reach in and connect the switch. I haven't tried this but I believe it will work.
roncallo is online now
post #3 of 5 (permalink) Old 01-03-2013, 09:45 AM Thread Starter
an ly's Avatar
Vehicle: 1987 560sl
Quoted: 7 Post(s)
Thanks Ron, for some reason wire does not want to come out of the hole to snap switch on, it seem short, so does the wire come out pass hole to snap on?
an ly is offline
post #4 of 5 (permalink) Old 01-03-2013, 09:52 AM
roncallo's Avatar
Quoted: 297 Post(s)
Yes it should come out at least an inch or so. Sounds like its getting hung up on something, perhaps rearranged wire routing during a stereo installation.
Actually now that I think of it Stereo removal may be the best option to get at the back of the switch.
post #5 of 5 (permalink) Old 01-03-2013, 09:54 AM Thread Starter
an ly's Avatar
Vehicle: 1987 560sl
Quoted: 7 Post(s)
Thanks Ron, will look at it after work, was afraid to pull anything, now I now it should come out. Thanks again
an ly is offline
