wire from distributor to coil - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 07-30-2011, 12:18 PM Thread Starter
Date registered: Jun 2011
Vehicle: 1973 mercedes benz 450 sl
I need to replace the wire that runs from the distributor to the coil on my 73 450 sl. I cant seem to find one anywhere online. If anyone has replaced this wire, where were u able to get it? It needs to have the end on it where it connnects to the distributor. Thanks
watchmedoit is offline
post #2 of 14 (permalink) Old 07-30-2011, 12:28 PM
It Is What It Is, Dude
isthisdave's Avatar
Date registered: Mar 2006
Vehicle: 1978 107.024 RIP
Quoted: 108 Post(s)
Typically the coil lead to the distributor is part of an ignition wire set. Web vendors aren't gong to sell individual wires. Local parts stores will have universal coil leads.
But MB might have individual leads. Check the EPC.
isthisdave is offline
post #3 of 14 (permalink) Old 07-30-2011, 11:09 PM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
I was able to get one from an Independent shop that had been in business for quite a while. They ad the bulk cable, the ends, and the hoods separately. I think I got it for about $12.00 all told. And one of the guys put it together for me.
Scott
RadioTek is offline
post #4 of 14 (permalink) Old 07-31-2011, 05:02 AM Thread Starter
This is the wire that runs from the base of the distributor to the coil, not the one from the distributor cap to the top of the coil.
post #5 of 14 (permalink) Old 07-31-2011, 06:59 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 106 Post(s)
The green wire that leads to the condenser and points? You can replace it with proper gauge wire and crimp or solder a new end on it.
rowdie is offline
post #6 of 14 (permalink) Old 07-31-2011, 10:58 AM
Vehicle: 1975 450SL
Quoted: 15 Post(s)
With your year, you should have a D-Jet ignition system. You should have a green wire going from the breaker points in the bottom of the Dizzy to a terminal on the switchgear. My '75 gear is right behind the driver's side headlight. There should be another wire going from the primary side of the coil to the switchgear. The switchgear does the actual switching of the coil(higher current/voltage), while the breaker points just send a (low current, lower voltage) signal to the switchgear. This is supposed to extend the life and reliability of the breaker points, while giving a better signal pulse to the coil.
If there is a special connector at the switchgear for your particular year, it may be necessary to go to M-B, or start to haunt scrapyards.
An explanation of the ignition circuit can be found in the online CD-ROM version of the manual here: Model 107
look for document 075.519.pdf after you click on your particular year/model.
Scott
RadioTek is offline
post #7 of 14 (permalink) Old 07-31-2011, 11:18 AM
3547fl's Avatar
Date registered: Nov 2009
Vehicle: 1989 560SL
Quoted: 50 Post(s)
I have a 76 450SL that is getting parted out. Would this have the same setup as your? Don't really know much about 450's.
1951 Oldsmobile Restoration Blog:
3547fl is offline
post #8 of 14 (permalink) Old 07-31-2011, 01:41 PM
MBGraham's Avatar
Date registered: Oct 2006
Vehicle: '72 350SL, '85 300D, '98 E320, '19 Subaru Outback (sold '14 GLK250)
Quoted: 20 Post(s)
This line should actually go to a connector located just below the coil near the resistors (Item 7 in sketch below shown with V pointing to it.)
The mb part you need is A 0001596918. I have switched to Pertronix so don't have that wire on my car any longer, but I do happen to have an unopened one in amongst my spare parts (see pic). This one is not same as the original wire. It includes the green wire, plus a black ground wire with terminals to connect to distributor and chassis ground at other end and the sleeve that fits into the distributor body.
You might consider replacing points with Pertronix 1885. Only cost about $70.00 (probably less than OE cable!) and eliminates having to ever fool with points again.
ID:	389326   Click image for larger version
Name:	djet ignition wiring.jpg
MBGraham is offline
post #9 of 14 (permalink) Old 07-31-2011, 07:04 PM
rowdie's Avatar
Quoted: 106 Post(s)
Pictures and communication would help. Why do you need to replace the wire?
rowdie is offline
post #10 of 14 (permalink) Old 07-31-2011, 07:24 PM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2334 Post(s)
Just as an aside, Jim...the wire from the ECU to the coil (the one with the big round connector) on the 280 SL in NLA.
If you happen to have one kicking around.......or anybody for that matter I would love to have it as mine is cracked at the connector. I dipped it in Gravel Guard (liquid rubber) to seal the crack but a better one would be nice.
Originally Posted by nobby View Post
Donítí ever wrestle with a pig. Youíll both get dirty, but the pig will enjoy it.
Originally Posted by rocky raccoon View Post
Soldier on Old Chap. The Pig is you and you are the Pig.
nobby is offline
testing a 79 w107 distributor pickup coil? dane727 Vintage Mercedes-Benz 0 02-25-2011 12:31 PM
Coil Wire Set? millerm77 R170 SLK-Class 9 11-09-2009 07:37 AM
ECU Coil wire Kingorcus W126 S,SE,SEC,SEL,SD,SDL Class 6 06-26-2006 01:08 PM
Anyone know how to remove the magnet and coil from under the rotor within the distributor? GotTheBenz W126 S,SE,SEC,SEL,SD,SDL Class 7 10-08-2005 07:06 PM
280 coil wire resistance??? HELP! Brent G-Class 6 09-30-2004 11:26 AM
