I need an intervention....dash removal...heater box repair... - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-05-2010, 05:47 PM Thread Starter
Date registered: Dec 2009
Vehicle: 1989 Astral Silver 560SL
It happened today. I was replacing the head unit in my 560SL. While it sounded ok for my 44 year old ears I just couldn't take the flashing red and blue lights. I bought a refurbished Becker with MP3 mod from Beckerautosound.com. Which I might add sounds better than the flashy unit...
There I am with the radio out....and it hits me.
Looking up on the underside of the header box I see that telltale crack in the box. I've read about the repair at length on this forum. I start to sweat, and shake a little as the compulsion hit me. "I must fix that, must take out dash and fix heater box...must"
So now I've got to do the scary dash removal and heater box repair. (my vents blow out air that could melt lead). I want to replace anything and everything....any thoughts on what I should replace?
For those that have done this, realistically how many actual hours did it take you.
Thanks.
EEHamilton is offline
post #2 of 3 (permalink) Old 09-05-2010, 06:27 PM
One of the BW Old Guard
Ears's Avatar
Date registered: Aug 2004
Vehicle: 1997 SL500- 40th Anniversary
Quoted: 492 Post(s)
I spent roughly 17 hours on the work I did, over three days... I took my time, no rush. If you visit my site, you can see John Roncallo's pictures of his repair efforts, and my efforts. John removed the dash and the top half of the heater box. I did the same repair from underneath, and did not remove my dash. Two methods of roughly the same repairs...
'ave fun!
Best Regards...
RM Smith
Where is it again that we are going... And why are we in a handbasket?
Ears is offline
post #3 of 3 (permalink) Old 09-06-2010, 06:18 AM
roncallo's Avatar
Date registered: Apr 2005
Vehicle: 1986 560SL with M120 V12 Engine, 1988 560SL Stock
Quoted: 297 Post(s)
I have done 3 in the last 3 years. It's allot of work but non of it is brain surgery. The main thing to be concerned about is that if your dash is not cracked it may be cracked when your done. If it is cracked then there are no real concerns. For a first time DIY, I would plan as follows. And yes you can beat the time but its not a race.
Day 1 Remove steering wheel, seat, center console and dash, taking photos all the way.
Day 2 Remove heater box and evaluate.
Day 3 Fabricate repairs to heater box and overhaul.
Day 4 Do over all the things that did not come out as planed during heater box repair.
Day 5 Install heater box and prepare dash for installation. This includes replacement and Locktight of the windshield wiper transmission bolts.
Day 6 Install dash and test systems.
Day 7 Install center console and seat.
Notice Ive given 4 days for removal repair and installation of the heater box. That is because the kind of repair you will be doing is unique to all situations. You will have to evaluate what is wrong and figure out a way to repair. This generally means numerous trips to the hardware store and lots of times scratching your head.
Minimum parts to start out with.
1) New screws for windshield wiper transmission, I believe there are 8 of them.
2) New inside air temperature sensor hose or search for various repairs of this hose.
3) At minimum 3 new pods used inside and on the heater box. I use new pods from MB only because I don't want to be back inside there for another 20 years. The 4 fresh air pods can be replaced later with the dash in place so they are optional.
4) All new bulbs for instrument cluster, Headlamp switch, AC unit and gear shifter.
Follow the CD exactly but there are some extra steps required for the 560 including the removal of additional switches and you will probably need to remove the mirror switch to release the center console wood.
Also search Peachparts SL forum for this
roncallo is offline
Dash/heater box removal mgrant R/C107 SL/SLC Class 45 05-21-2019 03:09 PM
Heater box repair Gabriel2000 R129 SL-Class 3 09-01-2009 05:33 PM
416 heater box repair drembedded Unimog 5 09-18-2007 12:09 PM
Dash removal for AC repair? MRBSMITH General Mercedes-Benz 4 03-29-2007 06:59 PM
Heater Box Repair, 560SL Ears R/C107 SL/SLC Class 2 09-16-2006 09:39 PM
