Quick question about warning lights - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 08-31-2010, 04:33 PM Thread Starter
decampos's Avatar
Date registered: Aug 2010
Vehicle: 1983 Mercedes 280SL
Quoted: 10 Post(s)
Hello there. Am I right in thinking that the strip of warning lights are meant to illuminate when the key is turned to the first position? They currently don't apart from the battery light.
Any ideas for the first course of action? fuses? the bulbs themselves?
Many thanks
Ben
decampos is offline
post #2 of 22 (permalink) Old 08-31-2010, 05:12 PM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2389 Post(s)
Many thanks
Ben
I'm trying to think what's there............turn signals, parking brake, charging system.......
does your parking brake and light signals work?
In any event if you haven't changed the bulbs in the cluster.....change them. You'll be plesently surprised at how much brighter the cluster will be.
Here's some pointers.
https://www.benzworld.org/forums/r-c1...-tutorial.html
Originally Posted by nobby View Post
Donítí ever wrestle with a pig. Youíll both get dirty, but the pig will enjoy it.
Originally Posted by rocky raccoon View Post
Soldier on Old Chap. The Pig is you and you are the Pig.
nobby is offline
post #3 of 22 (permalink) Old 08-31-2010, 08:33 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 111 Post(s)
You forgot mention adding a ground wire from the cluster to a good metal ground.
As long as you have the cluster out you might as well do it.
rowdie is offline
post #4 of 22 (permalink) Old 08-31-2010, 08:44 PM
Bob's Your Uncle!
nobby's Avatar
The link Jim.....it's all in the link.
nobby is offline
post #5 of 22 (permalink) Old 09-01-2010, 04:35 AM Thread Starter
decampos's Avatar
Quoted: 10 Post(s)
Thanks for the link. Will investigate. Hoping I didn't need to remove the wheel but looks straight forward. Dumb question: oil line? Do all cars have a physical oil line connecting to the cluster? Surely not.
So, all the warning lights should be illuminated with the key is turned to the first position?
Cheers
Ben
decampos is offline
post #6 of 22 (permalink) Old 09-01-2010, 04:50 AM
Nascar Fan's Avatar
Date registered: Feb 2007
Vehicle: 1980 450SL & 1988 560SL
Quoted: 2 Post(s)
oil lines went electronic some time AFTER 1980, but I don't know when. Easy to undo, just don't crank the engine with it unhooked or if you do take pictures.
My 1988 lights ALL the warning lamps when first cranked, but I don't recall the 1980 doing that.
Timing has a lot to do with the outcome of a Rain dance.
Rollin' restore on a
1980 450SL
1988 560SL
Pine Bluff, Arkansas
Nascar Fan is offline
post #7 of 22 (permalink) Old 09-01-2010, 04:56 AM Thread Starter
decampos's Avatar
Quoted: 10 Post(s)
Thanks for the reply. Okay, that makes sense. The ABS light doesn't come on among others. I'm cynically assuming bulbs were removed to make the car appear in better fettle than it is.
decampos is offline
post #8 of 22 (permalink) Old 09-01-2010, 06:15 AM
ScottinSoCal's Avatar
Date registered: Aug 2006
Vehicle: 2010 Mercury Milan Hybrid, 1993 BMW 325i convertible
Quoted: 20 Post(s)
Might have been. My dad's SL600 had several bulbs removed - including the Check Engine light - to make it look like it was in better shape than it was.
When I die, I want to go quietly in my sleep, like Grandpa.
Not screaming, like the people in his car.
Juvenis quod fanaticus nunquam concilio usus quod proditus
ScottinSoCal is offline
post #9 of 22 (permalink) Old 09-01-2010, 06:34 AM Thread Starter
decampos's Avatar
Quoted: 10 Post(s)
Yep. Some bulbs are missing. Here's a pic of one of them. Which sort are these for when I ask at the store?
Cheers
Ben
decampos is offline
post #10 of 22 (permalink) Old 09-01-2010, 08:09 AM Thread Starter
decampos's Avatar
Quoted: 10 Post(s)
Nevermind, I got 'em.
decampos is offline
Quick question about interior lights... Rashman C209/A209 CLK-Class 2 06-10-2009 01:05 PM
Quick question about Xenon lights. woostar88 W163 M-Class 1 08-26-2006 10:16 PM
Quick question on tail lights... ~BenzBoy~420-SEL~ W126 S,SE,SEC,SEL,SD,SDL Class 2 11-16-2005 07:35 PM
Clear Side Corner Lights (Quick Question) ecstaznsy W203 C-Class 12 08-26-2004 03:45 AM
Quick question about installing 2004 Halogen Lights Sub-Zero W163 M-Class 8 02-15-2004 06:10 PM
