Water Pump Replacement HOWTO on earlier 107's - Page 4 - Mercedes-Benz Forum
post #31 of 62 (permalink) Old 10-11-2010, 05:08 PM
Date registered: Sep 2010
Vehicle: 1985 380 SL
I have 1985 380SL, and I had to pull the balancer. New subject: after I finished my water pump project, I have a high idle problem. It was intermittent before. I went through the troubleshooting flow chart and found no voltage at the idle stabilizer, nor on pin 2 of the idle control unit plug. This is where things get wierd. The flow chart says check black/red cable between contact 2 and fuse 14. I found no continuity between those two points and furthermore when I checked the wiring diagram it does not show such a connection. It shows that pin 2 gets power from the OVP running from the relay contacts to a terminal (C185) to pin 2. ??? Anyone familiar with this area!
rjbucks is offline
post #32 of 62 (permalink) Old 09-16-2015, 05:43 PM
jaymaynard's Avatar
Date registered: Mar 2013
Vehicle: 2015 ML250 Bluetec, 62K miles; 1987 560SL, 121K miles
Quoted: 719 Post(s)
So, anyone know if you have to pull the distributor on a 1983 380SL? Or is there not a bolt lurking behind it?
And if you disconnect the transmission cooler lines, what do you use to cap them off so you don't dump out all of the transmission fluid?
There are three nuts you have to loosen on the power steering pump to loosen the belt, right? Upper left, lower left, lower right? I can't get the one on the lower right to loosen...
"Engineered like no other car in the world." That's both a bug and a feature.
jaymaynard is offline
post #33 of 62 (permalink) Old 07-06-2018, 09:20 AM
dragonflyer's Avatar
Date registered: May 2009
Vehicle: 1982 300SD, 1984 380SL, 1997 E320, 2008 R350
Quoted: 39 Post(s)
Getting ready to replace water pump on my 1984 380/500SL. So far, from what I've read, the only challenge will be the removal of the harmonic balancer. Anyone knows if I need to pull the distributor? Mine has a bolt holding it down, not a nut on the stud.
dragonflyer is offline
post #34 of 62 (permalink) Old 07-06-2018, 11:13 AM
jaymaynard's Avatar
Quoted: 719 Post(s)
Yes, you will need to remove the distributor. Make sure to rotate the engine (clockwise looking at it from the front) until it's at TDC on cylinder 1, with the distributor rotor pointing rearward, before you remove either the harmonic balancer or the distributor. If you rotate the engine with the distributor out, make sure to rotate it an even number of turns so you don't get the distributor 180 degrees out of phase. BTDT.
post #35 of 62 (permalink) Old 07-11-2018, 12:36 PM
Date registered: Oct 2014
Vehicle: 1981 380SL, 2012 GLK 350, 2008 Corvette, 2002 Nissan Xterra, 1965 Dodge Dart Wagon
Quoted: 39 Post(s)
You can do it without removing the harmonic balancer. I did. There is a notch at some point on the balancer. I believe that what I did was loosened the bolt that is blocked by the balancer with a wrench. You can then line the notch up with the bolt in question and use a nut driver to get it out. I think that when I went to put the bolt back, I started it using both of my index fingers. The nut driver didn't line up directly with the bolt hole so I couldn't use it to get the bolt started. Once it's lines up with the hole, thread it with the nut driver and then use a wrench to finish it up.
Mirv is offline
post #36 of 62 (permalink) Old 07-11-2018, 01:07 PM
Quoted: 39 Post(s)
Roger that, pull the distributor and try getting at the two lower bolts without removing the balancer. Thanks jaymaynard and Mirv.
post #37 of 62 (permalink) Old 07-11-2018, 08:53 PM
Guest
Posts: n/a
Quoted: Post(s)
I remember doing my 1984 500sl water pump. It's kind of funny, I had my a.c. compressor go out about a year before the water pump, when I looked into replacing the compressor and saw the amount of work I said I will wait till the water pump goes out... well it also went out, I did not have to remove the counter balance, but everything else had to come off. The complete front of the motor, radiator, fan, shroud, distributor all had to come out and when it was, the a.c. compressor was there so i replaced it too. But that is another story. Good luck it's not a hard job, I would just say think about any other things that could use to be replaced and do it all then.
God bless
post #38 of 62 (permalink) Old 07-11-2018, 08:57 PM
Guest
Posts: n/a
Quoted: Post(s)
It was a really long time ago, maybe 10 years. i will see if i have pictures to comfirm.
post #39 of 62 (permalink) Old 07-12-2018, 07:56 AM
It Is What It Is, Dude
isthisdave's Avatar
Date registered: Mar 2006
Vehicle: 1978 107.024 RIP
Quoted: 109 Post(s)
Cast iron blocks require neither damper or distributor be removed. Alloy blocked engines require distributor removal and iirc damper removal on the 560 only
cwmoser likes this.
isthisdave is online now
post #40 of 62 (permalink) Old 07-12-2018, 02:50 PM
Premium Member
Jyuma's Avatar
Date registered: May 2017
Vehicle: 1983 380 SL
Quoted: 759 Post(s)
Premium Member
I just replaced the water pump on my '83 380sl. Everything on the front of the engine with the exception of the A/C compressor had to come off... including the balance.
Sidebar: I was told that none of the bolts securing the water pump go all the way into the water jackets but a few of the bolts I removed had some rust on them and some (not much) water came out of a few of the holes. As a precaution I replaced "all" the bolts with new SS bolts and used Teflon reenforced thread compound on all the bolts.
Nobody gets out of this life alive.
Jyuma is offline
Water pump replacement on an ML ron in sc W163 M-Class 55 07-05-2018 10:40 PM
water pump replacement ronellis33 W210 E-Class 11 03-04-2015 10:57 AM
water pump replacement nwamurph67 R129 SL-Class 0 07-21-2010 10:14 PM
Water Pump Replacement MBNoMore W163 M-Class 3 10-05-2009 02:13 AM
2.6L water pump replacement help soos W201 190-Class 4 12-07-2006 10:33 PM
