Low Fuel Light Always On - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-15-2010, 08:19 PM Thread Starter
Date registered: Apr 2006
Vehicle: '84 280sl 5 speed
Send a message via AIM to dadette123 Send a message via Skype™ to dadette123
1984 280SL
Replaced all bulbs in the instrument cluster. Now, the low fuel indicator light stays on even though I know there is at least 3/4 of a tank. FYI, the gauge dances around and becomes erratic when below 1/2 tank. I haven't gotten around to adding a ground yet but pulled a strand of brown ground wire from another MB (I know, I know, the ground wire doesn't HAVE to be brown... I'm just anally retentive that way) so, will be doing so soon. Also, haven't pulled the fuel tank sending unit or screen yet.
So, tell me why the light is staying on all the time. Thanks. Oh, did a forum search and didn't find a directly relatable thread (happy to go there if someone points me in that direction).
Put it back together? Sure honey, no problem.
dadette123 is offline
post #2 of 7 (permalink) Old 03-15-2010, 08:31 PM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2334 Post(s)
I vote for fuel sender.
https://www.benzworld.org/forums/r-c1...er-repair.html
Originally Posted by nobby View Post
Donítí ever wrestle with a pig. Youíll both get dirty, but the pig will enjoy it.
Originally Posted by rocky raccoon View Post
Soldier on Old Chap. The Pig is you and you are the Pig.
nobby is offline
post #3 of 7 (permalink) Old 03-15-2010, 08:32 PM
Always Remembered RIP
petesmga's Avatar
Date registered: Aug 2009
Vehicle: 1979 280sl 4 sp w/ac 1957 MGA 1998 volvo xc/70 2004 F150
Quoted: 41 Post(s)
the light and sending unit are ground activated, so if you lost your ground while pulling the cluster, an erradic reading is possible. Remove your speaker to gain access to the back of the cluster and attach a temp ground wire and see what happens.
petesmga is offline
post #4 of 7 (permalink) Old 03-16-2010, 03:58 AM
Nascar Fan's Avatar
Date registered: Feb 2007
Vehicle: 1980 450SL & 1988 560SL
Quoted: 2 Post(s)
pulled my cluster yesterday for needle painting, clock repair and had gained about 1/2 a tank of gas and had the low fuel light too. I made me about a 16 inch wire and put one end under one of the streering shaft mounting bolts just behind the cluster and the other to the cluster ground screw. Lost that 1/2 tank of gas and the light.
I was very easy with the parts and still broke the ground somewhere. Did the same things on my 450 a few years ago when I did that cluster.
Timing has a lot to do with the outcome of a Rain dance.
Rollin' restore on a
1980 450SL
1988 560SL
Pine Bluff, Arkansas
Nascar Fan is offline
post #5 of 7 (permalink) Old 03-16-2010, 06:58 AM Thread Starter
Thanks. I'll try the new ground first and then, move on to the sending unit.
"I love it when a plan comes together." Hannibal
post #6 of 7 (permalink) Old 03-16-2010, 08:43 PM
Bob's Your Uncle!
nobby's Avatar
Originally Posted by dadette123 View Post
1984 280SL
If these symptoms only started AFTER fiddling with the cluster then I too vote for grounding the cluster.
nobby is offline
post #7 of 7 (permalink) Old 03-17-2010, 08:45 AM Thread Starter
No, the fuel gauge has been dancing since I got the car last year. Interesting note though, the gauge is now approaching 1/2 and I have not seen any sign of the needle starting its "Irish Jig" SINCE I pulled out the cluster last week and replaced all bulbs. The low fuel light is still on, though. I will add the additional ground first (thanks for the pics!) and see what happens.
low fuel light shull1949 R170 SLK-Class 5 08-03-2009 02:27 AM
Low fuel light blinking vronga R170 SLK-Class 8 08-28-2008 05:58 PM
No low fuel light? Benzboy210 W210 E-Class 3 02-27-2008 07:31 PM
What's going on? - Blinking "Low Fuel" light. J√ɬľri W163 M-Class 4 02-06-2002 02:44 AM
ASR, Cruise, Low Fuel Light, Park Brake light - all failed Ameet Patel R170 SLK-Class 1 03-29-2001 02:59 AM
