R107 Soft Top Replacement - Page 78 - Mercedes-Benz Forum
post #771 of 903 (permalink) Old 12-07-2015, 11:41 AM Thread Starter
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2359 Post(s)
Originally Posted by bereng View Post
Hi guys,
I.m buying my new top in the next two weeks and i intend to replace it during xmas holidays. 2 quick questions:
- how have plastic windows evolved since you replaced yours? Cracks? Marks?
- in your experience, would it be a good idea to go for a progressive top replacement instead of the usual big-bang approach? I mean 1st remove/intall back bow, 2nd B-pillar + mid bow remove + install new one, etc progress back to front one section at a time
You can use the old top for reference, alignement and it.ll be fresh in your mind each section you move onto...
Just an idea.
Thx in advance
A) Windows do seem to get neglected during the decision of what top to purchase. There is a science to that too.
My windows have held up quite well.
B) Hard to do the recommended "dry fit" with the old top still installed.
Your best friend should be a camera .
Originally Posted by nobby View Post
Donítí ever wrestle with a pig. Youíll both get dirty, but the pig will enjoy it.
Originally Posted by rocky raccoon View Post
Soldier on Old Chap. The Pig is you and you are the Pig.
nobby is offline
post #772 of 903 (permalink) Old 12-10-2015, 07:01 AM
jamesbond007's Avatar
Date registered: Jan 2007
Vehicle: 1989 300 SL (R107)
Quoted: 10 Post(s)
OEM Part numbers
All the parts one needs for an OEM installation:
A man is just a boy with bigger toys.
Middle age is that perplexing time of life when one has to choose between "why not?" and "why bother?"
jamesbond007 is offline
post #773 of 903 (permalink) Old 01-08-2016, 08:44 PM
My First 450SL's Avatar
Date registered: Nov 2013
Vehicle: Mercedes 1977 450SL
Quoted: 101 Post(s)
draft seal
Originally Posted by roncallo View Post
I also have to glue them on. Wide end goes forward. Thick edge overhangs on frame rails to the outside.
WARNING This is all been superseded according to Nobby's official service bulletin see next few post. Do no glue to rails. Cable hold seals tight to rails.
There seams to be no mention of these seals anywhere. I believe this gets glued to both the top and the frame rails. I say that because at one time I went through a touch less car wash with my black car because I assumed a touch less car wash could do no harm. All was going well until the dryer came on. It was probably the scariest moment of my life, as I thought the top was going to get blown right off. The only thing I noticed after the car wash was that the top was no longer attached to the side of the frame and the car has made really bad wind noise ever since. I can only assume it was bonded on before the car wash. But I cant see any evidence of adhesive on the rails of either car.
If so I think it would be best to glue it and let is set up on the frame rails first. There is a notch in the front of the seal, I believe that gets inserted under the front header as shown in the picture.
So with the side seal rails in place I would glue the notch into the front header then glue it down onto the seal retainers and let that glue setup before putting the top on.
Do experiment with this because I am by no means an expert.
Do you guys by chance know the part number to this seal...I restarted my top install and discovered my seals are damaged and I need to get new ones.
My First 450SL is offline
post #774 of 903 (permalink) Old 01-08-2016, 08:46 PM
Quoted: 101 Post(s)
Sorry...I am stupid...just saw post above...thanks jamesbond007
post #775 of 903 (permalink) Old 02-11-2016, 09:17 PM
Quoted: 101 Post(s)
So I finally remembered I never finished my top. I got the glue recommended by Nobby...here we go.
cwmoser likes this.
post #776 of 903 (permalink) Old 02-11-2016, 09:57 PM Thread Starter
Bob's Your Uncle!
nobby's Avatar
Fuck, T....you might as well wait until April, now.
What a slacker.
nobby is offline
post #777 of 903 (permalink) Old 02-11-2016, 10:06 PM
Quoted: 101 Post(s)
So I got the back glued down.
post #778 of 903 (permalink) Old 02-11-2016, 10:38 PM Thread Starter
Bob's Your Uncle!
nobby's Avatar
Get that rear seal installed....
nobby is offline
post #779 of 903 (permalink) Old 03-09-2016, 05:49 AM
Date registered: Feb 2013
Vehicle: 1987 560 sl
Quoted: 4 Post(s)
i just ordered a new top and seat covers from tops on line as my top needs replacing. does anyone know where to find a reas tension cable? TOL dosnt have them, or know what the part number is? when i get into this project i will send pictures to show how i am faring with it..thanks
Jubb is offline
post #780 of 903 (permalink) Old 03-09-2016, 10:32 AM Thread Starter
Bob's Your Uncle!
nobby's Avatar
I got mine at MB, I believe.
But TOL is not the only supplier....I'm sure there are others that carry the rear cable.
nobby is offline
Soft top replacement erpope C208/A208 CLK-Class 26 02-18-2009 03:20 PM
Soft Top Replacement Leanfwdc R129 SL-Class 14 07-20-2008 11:17 PM
SL Soft Top Replacement mslchief R/C107 SL/SLC Class 4 01-20-2007 01:20 AM
Soft-top replacement Steve T G-Class 0 08-22-2001 11:54 AM
