Example of a bad 107 front sub-frame, subject of recall. Pictures of crack failure. - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 01-05-2009, 02:41 PM Thread Starter
PWogaman's Avatar
Vehicle: 80 280SL, 85 300SD, 87 300TD, 90 300TE 4Matic, 90 300D 2.5 Turbo, 92 300D 2.5 Turbo, 92 300TE 4Mat
Quoted: 36 Post(s)
Exclamation Example of a bad 107 front sub-frame, subject of recall. Pictures of crack failure.
I finally got around to disassembling my 1976 450SL (107) parts front sub-frame. I was planning on cleaning it up and then swapping it out into my 1980 280SL (107). Here is what I found (good thing I also have (had) a 350SLC parts car). Perhaps the front sub-frame on it will be in better shape.
This exact failure is the subject of a recall. If there are no cracks MB will weld brackets on the hole flanges. If it is cracked they are supposed to replace it. I'm going to see if I can get MB to replace the sub-frame - for free even though it is not still on the car.
PWogaman is offline
post #2 of 14 (permalink) Old 01-05-2009, 03:36 PM
roncallo's Avatar
Date registered: Apr 2005
Vehicle: 1986 560SL with M120 V12 Engine, 1988 560SL Stock
Quoted: 297 Post(s)
Wow you should have drove the car to the dealer first for the subframe recall. The deal is as I understand it, If your subframe is actually cracked when they go to do the service they have to replace it with a new 560SL strengthened type. They you would have had a new one for your 280SL
roncallo is offline
post #3 of 14 (permalink) Old 01-05-2009, 04:06 PM Thread Starter
PWogaman's Avatar
Quoted: 36 Post(s)
There was no driving it when I got it. It was a parts car from the get-go. Perhaps if I take the title and sub-frame to a dealer and say I'm rebuilding it myself, and "Look what I found!" They can check on their system and see it has not yet been done - that way they'll have a VIN to charge it to. I figure I've got nothing to loose.
PWogaman is offline
post #4 of 14 (permalink) Old 01-05-2009, 05:07 PM
roncallo's Avatar
Quoted: 297 Post(s)
That may actually work. It may even work better if you have an MB Tech do it. He might be able to swing a warranty claim out of it.
roncallo is offline
post #5 of 14 (permalink) Old 01-05-2009, 05:23 PM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2411 Post(s)
Where would you weld a gusset onto that?
nobby is offline
post #6 of 14 (permalink) Old 01-06-2009, 01:21 AM
bondavi's Avatar
Date registered: Sep 2004
Vehicle: 1983-2007 MB's
Quoted: 836 Post(s)
I understand MB doesn't honor the recall for Euros, unfortunately.
bondavi is offline
post #7 of 14 (permalink) Old 01-06-2009, 01:47 AM
Bob's Your Uncle!
nobby's Avatar
Not willingly, but they have.
nobby is offline
post #8 of 14 (permalink) Old 01-06-2009, 03:30 AM Thread Starter
PWogaman's Avatar
Quoted: 36 Post(s)
Talking
I've heard that, but my 450SL is a U.S. model.
PWogaman is offline
post #9 of 14 (permalink) Old 01-16-2009, 06:52 PM
roncallo's Avatar
Quoted: 297 Post(s)
How did you make out on this. Able to get a new one???
roncallo is offline
post #10 of 14 (permalink) Old 01-20-2009, 07:44 PM Thread Starter
PWogaman's Avatar
Quoted: 36 Post(s)
I haven't tried yet. I've been too busy stripping cars at Johnhef's place.
PWogaman is offline
Sub Frame failure help JDR280SL R/C107 SL/SLC Class 30 12-21-2016 07:25 PM
WARNING Know what you need to know! Mercedes 107 Sub-Frame Recall Enlightened! kmbonomo R/C107 SL/SLC Class 55 04-12-2012 06:37 AM
Sub-Frame Failure on 280SL (Euro) JDR280SL R/C107 SL/SLC Class 135 10-01-2011 07:43 AM
107 Subframe Recall question. monza1962 R/C107 SL/SLC Class 1 11-10-2004 05:56 PM
Subframe recall for SL 107 73-80 not being honoured? DeidreB R/C107 SL/SLC Class 0 07-19-2004 02:33 PM
