Nice solution to cruise control hell. - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 09-25-2008, 02:22 PM Thread Starter
Nascar Fan's Avatar
Date registered: Feb 2007
Vehicle: 1980 450SL & 1988 560SL
Quoted: 2 Post(s)
I finally got fed up with a silly vacuum control cruise and installed a digital servo unit from Rostra. It's their universal model 250-1223 and cost around $160. Here is the nice part, it will interface with OEM stalk, VSS sensor and brake light setup. It's a digital unit where you can tap up and down in speed where 1 tap = 1 MPH and it required no vacuum. One programmable self-contained package makes a nice neat install. I installed it in half a day working at a "i'm on vacation pace". No special bracket needed for the cable hook-up as it had a cable end that fit right in the factory bracket.
So-long to the cruise amps and vacuum servo crap.
By the way, test drive was without exception. Works slick as a baby's ass. Anyone wanting to install one, I can save you some time with setting and wire connections.
Timing has a lot to do with the outcome of a Rain dance.
Rollin' restore on a
1980 450SL
1988 560SL
Pine Bluff, Arkansas
Nascar Fan is offline
post #2 of 12 (permalink) Old 09-25-2008, 03:24 PM
daryn's Avatar
Date registered: Nov 2004
Vehicle: 1978 280slc
Quoted: 54 Post(s)
Cool, sounds good. I hate that they used vacuum for everything, but that's the way it is. Cruise is about the only option I wish I had, but I have enough problems as is.
My dad was telling me about an old buddy who installed and aftermarket cruise control on a mazda. I guess you put magnets on the drive shaft and it reads the speed like one of those bicycle speedometers. Well I guess the magnets eventually loosened up and ding ding ding they flew of on te freeway. A funny story.
Ich brauch Geld fur Gasolin, explosiv wie Kerosin, mit viel Octan und frei von Blei- Gib mir Benzin!
daryn is offline
post #3 of 12 (permalink) Old 09-25-2008, 06:36 PM
abiby's Avatar
Date registered: Jul 2008
Vehicle: 82 380SL 96 SL500 03 SL500
Quoted: 298 Post(s)
Attachment 197064
Great. I had no idea that they still made aftermarket cruise controls.
I'm certainly not a purist so I wouldn't think twice about installing one on my car and it sounds like a very reasonable option.
Luckily I don't need one... yet.
Alan
If it doesn't fit, force it.
If it breaks, it needed replacing anyhow.
abiby is offline
post #4 of 12 (permalink) Old 09-25-2008, 08:12 PM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2408 Post(s)
My cruise works best once the pain in my right leg turns to numbness.
Originally Posted by nobby View Post
Donítí ever wrestle with a pig. Youíll both get dirty, but the pig will enjoy it.
Originally Posted by rocky raccoon View Post
Soldier on Old Chap. The Pig is you and you are the Pig.
nobby is offline
post #5 of 12 (permalink) Old 09-26-2008, 12:05 AM
daryn's Avatar
Quoted: 54 Post(s)
I know nobby said he drove his car from SC or somewhere 16 hours straight so he knows the pain. The baddest I did was 12hours and man the seats are nice until the lower back starts giving out. The leg is the least of the worries. The only sleep cure I found to work really well was tabacco and my lungs can't handle it no more.
daryn is offline
post #6 of 12 (permalink) Old 09-26-2008, 12:06 AM
HalNineThousand's Avatar
Date registered: Oct 2007
Vehicle: 1985 380SL, 1998 230SLK
You feeling okay, Nobby?
Overworked, perhaps?
First you just walk right by a setup I give you and everyone else as a great straight-man line, and now you give us lines like this that are just way too easy.
Must be overwork.
Or maybe it's the change in the weather.
HalNineThousand is offline
post #7 of 12 (permalink) Old 05-17-2009, 07:11 AM
Date registered: Jun 2005
Vehicle: 1979 450 SL, 144K
Nascar Fan,
Does the digital upgrade use the existing CC control stalk or does the kit come with a replacement. I couldn't tell from their site.
Thanks
juice1492 is offline
post #8 of 12 (permalink) Old 05-17-2009, 11:17 AM Thread Starter
Nascar Fan's Avatar
Quoted: 2 Post(s)
Originally Posted by juice1492 View Post
Nascar Fan,
Thanks
You can use the OEM stalk. You just need to map out the wires that go to the old cc amp and butt splice them to the new wiring harness.
1980 450SL
1988 560SL
post #9 of 12 (permalink) Old 04-12-2012, 09:38 AM
tbeede's Avatar
Date registered: Jan 2012
Vehicle: 1985 mercedes 380sl
Iam looking to install the same system on my 380sl. Do you remember the switch setting for pluse rate? Any help would be appreciated.
Thanks Tom 404-889-5863
tbeede is offline
post #10 of 12 (permalink) Old 04-12-2012, 05:48 PM
Date registered: Aug 2008
Vehicle: 1985 380SL, 2009 E320 Bluetec
Great Idea - any info would be appreciated
I'd love to do this with my 85 380sl. How are the instructions and do you have any insights. I'd like to use my original stalk so tips and tricks would be appreciated.
A how to post with pictures would great
Dan
mb380sldms is offline
Nice lil Cruise in Washington DC (vid) Abu Ali W123 E,CE,D,CD,TD,TE Class 1 11-23-2007 07:54 AM
Climate control hell Moodie W123 E,CE,D,CD,TD,TE Class 4 05-15-2006 09:58 AM
Cruise control display question. Does you car display the cruise control speed in the lower display? aquascape R171 SLK-Class 42 01-15-2006 01:37 PM
cruise control vs. climate control CCarlisle W123 E,CE,D,CD,TD,TE Class 0 11-04-2005 09:51 PM
Fitting Cruise control to a non-cruise car - Is it possible? ScrapingScrap W126 S,SE,SEC,SEL,SD,SDL Class 2 08-08-2004 09:34 AM
