Fuel sender repair - Page 3 - Mercedes-Benz Forum
post #21 of 41 (permalink) Old 02-08-2016, 01:05 PM
Date registered: Jun 2014
Vehicle: 1974 450SL, previously 1986 420SEL
Quoted: 47 Post(s)
How hard is it to get at the sender and get it out to repair it?
PEvans is offline
post #22 of 41 (permalink) Old 02-08-2016, 01:29 PM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2334 Post(s)
Access is under that big plastic plug in your soft top stowage compartment.
Originally Posted by nobby View Post
Donítí ever wrestle with a pig. Youíll both get dirty, but the pig will enjoy it.
Originally Posted by rocky raccoon View Post
Soldier on Old Chap. The Pig is you and you are the Pig.
nobby is offline
post #23 of 41 (permalink) Old 02-08-2016, 03:55 PM
ivanuf's Avatar
Date registered: Aug 2015
Vehicle: 1981 500SL
Quoted: 10 Post(s)
Once you remove the plastic cap, unscrew the sending unit and you are done. It takes about 3-5 minutes.
ivanuf is offline
post #24 of 41 (permalink) Old 02-08-2016, 04:13 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 106 Post(s)
Not necessarily true on the early models. On them there are several 8MM? nuts to remove. It is not the 46MM screw on.
rowdie is offline
post #25 of 41 (permalink) Old 02-08-2016, 07:45 PM
reno4u2's Avatar
Date registered: Dec 2009
Vehicle: 1988 560SL (California Model)
Quoted: 827 Post(s)
Seems like we had a post a couple of years ago where the 46mm socket wouldn't fit because the gas tank was mounted a little off and the sender was not centered in the access hole. Searched but couldn't find it. IIRC the op had to grind off some of the metal on the outside of the socket to make it seat.
reno4u2 is offline
post #26 of 41 (permalink) Old 02-09-2016, 03:59 AM
rowdie's Avatar
Quoted: 106 Post(s)
I think that was the tank screen.
rowdie is offline
post #27 of 41 (permalink) Old 02-09-2016, 04:15 AM
roncallo's Avatar
Date registered: Apr 2005
Vehicle: 1986 560SL with M120 V12 Engine, 1988 560SL Stock
Quoted: 297 Post(s)
That's exactly why I haven't replaced my tank screen.
roncallo is offline
post #28 of 41 (permalink) Old 02-09-2016, 04:20 AM
ivanuf's Avatar
Vehicle: 1981 500SL
Quoted: 10 Post(s)
I took the sending unit out and measured the lenght of the resistor cable from the contact points when the float is all the way down. The distance is about 15" of cable. Based on a target reading at that position of 69 Ohms. We will need a cable with a resistance of about 55.20Ohms/ft. Looking at the ones available I will say a 38 awg cable has a resistance of 53.60 Ohms/ft, that is close enough for me. I will order the cable. And I will post the results once installed.
ivanuf is offline
post #29 of 41 (permalink) Old 02-09-2016, 03:17 PM
Quoted: 47 Post(s)
You're kidding me. You mean I could have a functional gas gauge rather than waiting for the reserve light?
PEvans is offline
post #30 of 41 (permalink) Old 02-17-2016, 09:22 AM
ivanuf's Avatar
Vehicle: 1981 500SL
Quoted: 10 Post(s)
Update, I got the 38 AWG resistor wire, all 100ft. I proceeded to weld the wire to the fuel sending unit and....... it works. I got a functional fuel sending unit!!.
The only note that I have is that the reading from testing the sending unit outside the tank do not move the needle 100% to the Full or Empty positions. The needle stays goes 90% of the way to full and it stays 10% short of Empty. I guess there still some different gauge cable that will take it all the way to Full or Empty.
But still a 90% accurate sending unit for $6.00 and I can live with that!
reno4u2 likes this.
ivanuf is offline
Fuel sender removal jimmyl W123 E,CE,D,CD,TD,TE Class 6 06-11-2008 06:14 AM
Fuel sender curbill W123 E,CE,D,CD,TD,TE Class 2 04-17-2008 01:19 PM
Fuel level sender bigmellon Unimog 2 12-10-2007 07:45 AM
fuel sender repair? iNeon W123 E,CE,D,CD,TD,TE Class 3 03-20-2005 08:29 AM
Fuel Level Sender Repair article up in G-tech section of ClubGwagen site Hipine G-Class 0 11-17-2002 07:02 PM
