Mercedes-Benz Forum (https://www.benzworld.org/forums/)
-   R/C107 SL/SLC Class (https://www.benzworld.org/forums/r-c107-sl-slc-class/)
-   -   Dash creaks & rattles (https://www.benzworld.org/forums/r-c107-sl-slc-class/1294491-dash-creaks-rattles.html)
Playtime 12-16-2006 08:13 AM
The first long drive has brought out a 'chorus' of new cabin noises. Most are like 'creaks' that seem to be from lower dash (both sides) and the instrument binnacle.
All that plastic/vinyl rubbing against each other may be a 70's fetishists wet dream, but its turning me off:D
Various mechanics have had dash parts off and so i suspect basic fit and mounting isn't great.
1) Do any of the manuals depict how the dash parts should be mounted?
2) Does anyone know of a lubricant product that could be applied between these 'rubbing' surfaces to keep them silent?
3) The Instrument/gauge binnacle seems to move forward during driving! How is this supposed to be kept in place?
Thanks,
Paul
ScottinSoCal 12-16-2006 08:45 AM
Silicone spray will lubricate the rubber and keep it quiet. It gets everywhere, though, and the overspray is difficult to clean up. At work we use Simple Green Insdustrial to clean up silicone contamination.
There's a rubber gasket that wraps around the instrument cluster and keeps it in place. The first time I removed mine, the tape (duct tape?) that had been holding it in place was shot and wouldn't hold it there any more. It had turned into a gummy mess and a scrap of weave and plastic. I cleaned it all up, laid the rubber gasket out flat and sprayed it with a spray-on adhesive, then wrapped it around the instrument cluster the way it was supposed to be. It hasn't come loose since and the piece stays in place when I put it in.
Djenka018 12-16-2006 03:07 PM
or... you could use simple talkum for lubrication.
Easier to control dust than oil.
Playtime 12-16-2006 09:33 PM
Ending the arguement once and for all, that i really do 'baby' the car waay too much:D
But thanks both, off to give it a go now.
Cheers.
nobby 12-16-2006 09:34 PM
Keep the top down and the music up. Problem solved. Works for me.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
