The collider broke - Page 2 - Mercedes-Benz Forum
post #11 of 40 (permalink) Old 09-19-2008, 07:20 AM Thread Starter
Outstanding Contributor Always Remembered RIP
eric242340's Avatar
Quoted: 334 Post(s)
Originally Posted by QBNCGAR View Post
Feels great but doesn't stop until it gets 5 gallons.
The milking cups are too small for my dogs dick, the 5 gallon bottle on the other hand
ERIC.
This definition tells you all you need to know about 'PC'
PC, aka, Political Correctness, is a doctrine, fostered by a delusional, illogical minority (Liberals/Socialists) and promoted by the mainstream media, which holds forth the proposition that it is possible to pick up faeces by the clean end.
eric242340 is offline
post #12 of 40 (permalink) Old 09-19-2008, 07:23 AM
Date registered: Sep 2004
Vehicle: 2014 E250 Bluetec 4-Matic, 1983 240D 4-Speed
Quoted: 639 Post(s)
While I am entirely ignorant on the detail design of the new sub atomic particle examination instrument, I am very familiar with nuclear power plant design details. I am also fully aware of the TMI incident. The problems with such systems is they use humans to run them, and humans do dumb things because they get bored.
TMI failed because a pressure relief valve failed open. The valve drained the primary fluid from the plant. The operators had the status of the valve, open, displayed on their control panels and decided the valve was ok and the position sensor was wrong. Then they had instruments tell them the water level was too low, and decided those instruments were wrong. Then they had an indication that the fuel temperature was too hot and decided that could only happen if they were melting down, and ignored that. l
If you want a world with no machines that break down, get rid of the humans. Most car accidents happen because of incompetence by the operator. Even in cases where the manufacturer gets blamed, like the Firestone tires on Ford Explorers accidents. People were driving those vehicles with very low air pressures. And the Ford engineers "fixed" a suspension problem with lower than normal air pressure in the tires, making the likelihood of unsafe air pressures increase substantially.
Humans are the problem. With a new machine like the instrument you are so scared of the human error factor is generally lower. Humans get more incompetent when what they are doing is repetitive and boring. Like watching a status board in a control room with blinking red and yellow lights. Not quite the same as running away from a tiger or a bear to stay alive. Jim
JimSmith is offline
post #13 of 40 (permalink) Old 09-19-2008, 07:39 AM Thread Starter
eric242340's Avatar
Quoted: 334 Post(s)
Jim, I have to agree with you. There is the engineering factor and the scientific user factor but there is always a human factor.
Look at a simple thing like taking an aircraft up, two most common faults in accidents are engine/auronotics failure and human error.
We have been flying around the world for years and accidents still happen. But the CERN project is the biggest experiment ever undertaken in engineering terms. So when someone tells me it is 100 pc safe I will not believe them.
ERIC.
post #14 of 40 (permalink) Old 09-19-2008, 09:33 AM
Date registered: Feb 2006
Vehicle: 1999 ML320
Quoted: 313 Post(s)
If you actually read the articles, you will realize that physicists have NO idea of what may happen which is part of the mystery they are trying to unravel in the first place using the collider.
Originally Posted by dope View Post
mlfun is offline
post #15 of 40 (permalink) Old 09-19-2008, 09:51 AM Thread Starter
eric242340's Avatar
Quoted: 334 Post(s)
That I understand but do they, the phhysicists, understand the engineering of such a device? and what can go wrong on an (engineering level)?
ERIC.
post #16 of 40 (permalink) Old 09-19-2008, 09:59 AM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 1390 Post(s)
Relax Eric. It's not like the thing was made in China.
"2016 will go down in history as the year America lowered its expectations beneath the threshold of a first world country"
GeeS is offline
post #17 of 40 (permalink) Old 09-19-2008, 10:00 AM Thread Starter
eric242340's Avatar
Quoted: 334 Post(s)
Are you sure of that?
Do you actually know where the seat you sit on comes from? Made by bosch is just a joke nowadays.
ERIC.
post #18 of 40 (permalink) Old 09-19-2008, 10:01 AM
GeeS's Avatar
Vehicle: 2021 SL770
Uh, no.
GeeS is offline
post #19 of 40 (permalink) Old 09-19-2008, 10:09 AM
Date registered: Apr 2006
Vehicle: Caretaker '11 GLK RWD, '04 C240 4matic- totaled, '92 500SL-sold, 95 320E-sold, 85 300TD-sold
Quoted: 246 Post(s)
Whats the big deal- if it blows it'll all be over in a nanosecond, you won't even be able to process the fact that it happened- beats the hell out of cancer
Still remember the final shot of Dr Strangelove where ol' Slim is riding the H bomb to the ground
sualk54 is offline
post #20 of 40 (permalink) Old 09-19-2008, 10:10 AM Thread Starter
eric242340's Avatar
Quoted: 334 Post(s)
Uh, no.
I think CLKMan had a couple of chairs that were most probably made in Cina or maybe his is simply fat lol. This type of construction is serious and a first time event
ERIC.
broke in SikSlk99 R170 SLK-Class 18 03-10-2007 02:30 PM
I think I broke it. Help? DieselBear W123 E,CE,D,CD,TD,TE Class 1 03-09-2007 07:05 AM
ok, i'm going for broke.... sagamol General Mercedes-Benz 7 07-12-2005 04:07 PM
Broke down again!!! simon R170 SLK-Class 0 09-20-2002 05:56 AM
New G broke steve G-Class 5 06-18-2002 09:51 AM
