2005 E320 side airbags deployed while on a lift - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-28-2019, 02:30 PM Thread Starter
Date registered: Aug 2010
Vehicle: 05 e320 CDI, 99 TDI Beetle, 96 Dodge Ram Cummins
The car was up on a lift getting new flex discs and engine mounts. One of the transmissions tunnel bracket bolts wouldn't come loose so we used a hammer blow impact torx and a 2 pound hammer. On the second blow, the driver's side curtain, driver's seat and driver's side rear door airbags deployed. The hammer was swung upwards so the blow couldn't have been that heavy.
This car has 309,000 miles and I've put the last 217,000 miles on it since 2010. I'm the only driver. I've never had an accident, much less a side accident. None of the airbags have been replaced, serviced or moved from their factory locations since I've had the car.
I just remembered some upholstery work I had done on the driver's seat 3 years ago...had the seat back left side panel replaced where it had worn from all the sliding into and out of the door. This panel is directly in front of the seat back airbag thats located on the left side of the seat back. Wonder if the upholstery place disturbed that airbag and it's been waiting all this time to go off. Wonder if it did go off first and set off the others.
Anyone have any experience with this? Anyone know of any applicable service bulletins or recalls related to this?
Can a car upholstery place replace the airbags?
Pipe up with any and all thoughts or suggestions.
thanks,
Joel Wilkins
wilkinsjoel is offline
post #2 of 4 (permalink) Old 05-04-2019, 04:04 AM
Purple Moderator
Date registered: Jul 2005
Quoted: 1500 Post(s)
As discussed in your other thread the sensor on the bottom of the car near were the stuck bolt is
was more than likely tricked by the pounding of the hammer.
We had a 2005 that had the side bags deploy after the car went over a 3 inch ice ridge in the winter
at 35 mph.
I have not found any bulletins or recalls on the issue.
Noodles is offline
post #3 of 4 (permalink) Old 05-04-2019, 04:59 AM Thread Starter
at 35 mph.
Thank you for the information, Noodles. My plan is to find replacement airbags and fix the car. And then NOT pound on the belly before disabling the airbag sensor.
post #4 of 4 (permalink) Old 05-09-2019, 01:09 PM
Date registered: Aug 2008
Vehicle: 2003 clk 500
Wow thatís crazy
fufuflavor is offline
  Mercedes-Benz Forum > General Mercedes-Benz Forums > MB Safety & Testimonials
2005 E320 CDI for sale bart_dood For Sale/Wanted/Trade/Giveaway 2 02-17-2019 09:03 AM
Bosch CP3 pump teardown, rebuild and maintenance (with pics!) 2005 E320 CDI mightydisaster W211 E-Class 4 10-17-2017 04:18 PM
2005 E320 4 matic side mirrors E320c2 W211 E-Class 1 05-07-2009 01:12 PM
Oil Change 2005 E320 jlomon W211 E-Class 9 04-17-2009 07:53 PM
Lifting The Gelandewagen Karl Ingolfsson G-Class 40 11-19-2004 03:13 AM
