Superficial corrosion on aluminum engine blocks - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-20-2019, 05:51 AM Thread Starter
Date registered: Jun 2019
Vehicle: 2013 E350 Coupe, 2006 E320 CDI
Lightbulb Superficial corrosion on aluminum engine blocks
Has anyone found a good treatment to eliminate / prevent the filiform corrosion on aluminum engines that won't damage alternators, belts, etc? Thanks.
helisales is offline
post #2 of 2 (permalink) Old 06-20-2019, 10:31 AM
Supporting Vendor
AutohausAZ's Avatar
Date registered: Dec 2004
Vehicle: Too Many to List
Quoted: 31 Post(s)
From this page: https://www.pfonline.com/articles/ho...aluminum-alloy
"The damage is not extensive to the aluminum but is cosmetically objectionable, especially when the track is long and white in color."
"This type of filiform corrosion can damage all types of aluminum products such as wheels, automobile bodies and aircrafts. To repair the effect requires sanding and the application of a new layer of coating. To prevent filiform corrosion, proper surface pretreatment is required."
"The most important factor for the coating is to have very strong adhesion to the substrate to prevent the corrosion from starting."
Visit the AutohausAZ Vendor Section for special pricing for Benzworld members:
AutohausAZ is offline
