Can you flash or renew 725 9g TCU ETC - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-12-2019, 06:24 PM Thread Starter
Date registered: Feb 2009
Vehicle: 2017 W222 S550, 2015 W217 S550, 2017 W166 GLS550
Quoted: 6 Post(s)
Does anyone have the ability to either renew or clone a transmission controller plate from a 725 transmission on 2017 Mercedes gls550 with 9g fbs4 transmission part number 7252709011
I have the original plate with a faulty sensor plus an identical used plate
Not sure if it's possible to clone my original or simply renew the used one so that it can be scn coded. I know they are part of the DAS, unsure if they can be read and reflashed
If someone could help me do it i'd pay of course, or of you can do it there, I can mail them to you
I do have following diagnosis/programmers
Star C4
Drew Tech Cardaq 2 (j2534)
Abtites AVDI
ECOM Actia DOIP
tferrari is offline
post #2 of 3 (permalink) Old 04-13-2019, 08:44 AM
Kajtek1's Avatar
Quoted: 1959 Post(s)
Deplore is SDS guru on this forum.
Send him PM.
tferrari likes this.
Kajtek1 is offline
post #3 of 3 (permalink) Old 04-13-2019, 09:13 AM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 828 Post(s)
Star C4
Abtites AVDI
ECOM Actia DOIP
If all you have is speed sensor failure contact this outfit.
https://circuitboardmedics.com/merce...te-tcm-repair/
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
W203 C230 Flash To Pass & High Beams Not Working BenzManNow W202 C-Class 19 12-30-2018 02:55 AM
1996 SL500 Turn Signal Fast Flash Both Sides AlanBob R129 SL-Class 17 11-21-2015 01:40 PM
Turn signal lights up but does not flash. catfell W123 E,CE,D,CD,TD,TE Class 12 06-27-2015 10:18 AM
Parking Lights Flash 3 times when locking the car with remote. Is this Normal? LeeChiu R170 SLK-Class 12 07-19-2005 10:43 AM
high beam flash not working Naomilla2.0 W126 S,SE,SEC,SEL,SD,SDL Class 8 10-26-2004 12:19 PM
