FAULTY RADIATOR COOLER TANKS - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 03-05-2008, 06:54 PM Thread Starter
juxtamit's Avatar
Date registered: Aug 2006
Vehicle: 1980 300SD, 1992 Jetta w/ 2.0 ABA conversion, 1968 Ford LTD and 1965 Ford Fairlane
Causes tranmission failure
According to Mercedes Benz Star Bulletin #P-B 27.55/50f, dated March 24, 2006, there is a problem with Valeo radiators up to production date 9/2003 installed in models:
203.040/061/064/065/081/084/261/264/281/284/740/747/746 also
209.365/375/376/465/475 and finally
211.065/070/076/083/265/283
The problem occurs when the coolant leaks from the defective radiator through the cooler tank into the tranmission, resulting in damage to the tranmission and torque converter. Unlike earlier types of coolant and tranmission fluids synthetic coolant and tranmission fluid mix very well together. Mercedes does offer a test kit to check for the presence of glycol in the trans fluid, but this test is expensive and even if the test is negative at the time there is no gaurantee that a leak won't occur later. In event of transmission failure it is STRONGLY recomemmended to replace the radiator as part of the repair on any of the above listed automobiles.
juxtamit is offline
Bush tanks FeelTheLove Off-Topic 23 08-30-2005 03:29 PM
Radiator Replacement, Oil Cooler, Viscous Fan Clutch ericgr R/C107 SL/SLC Class 1 09-18-2004 09:38 AM
Gas tanks bterpstra G-Class 0 10-02-2002 09:23 PM
Auxiliary tanks mattG320 G-Class 0 06-16-2001 05:16 PM
