AMG63 ENGINE (M157) FAILURE - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-02-2019, 07:47 AM Thread Starter
Date registered: May 2019
I just had my AMG GL63 M157 engine failure (locked) on Tuesday, and awaiting what happened
14 days ago I took my car for the MB dealership service in North NJ to fix the vacuum door lock, and inspect the transmission that was a bit jerky on low speed. They did a 5mls road test, but was unable to find anything. Instead they fixed the door lock, also did the recall (2018070015 and replaced the dipstick of active curve system). The dealer also recommended to;
1. Change the transfer case input shaft seal (removed lower engine panels, detached drive shaft, removed cross memeber, removed transfer case and replaced input shaft seal).
2. Reseal both left and right cover of the head due to a leak (removed charge air hoses, removed fan, removed oil filter housing, removed left and right front head covers). Cleaned and resealed head covers, CAM SOLENOIDS and oil filter housing.
Total: $3,841
When I picked the car at closing time, I noticed misfire. The service guy was gone, and I stopped and restarted the car about 3-4 times after-which the misfire was gone. Thought it needed some "learning to reset". Next day another service rep called for courtesy follow up, and I mentioned the problems, and she said she will left a note to the rep for follow up, which never happened. I then drove the car about 14 days, 140mls, running normal. Got message on the morning to add 1QT of oil (maybe because of the service they did), added the oil, and headed to work, this Tuesday driving about 40-50mls/h the engine shut off itself after 30min of driving, and had the car towed to the same MB dealership.
The engine had codes for P0368, PO343, PO392, PO347 (camshaft position), and also PO106 (manifold absolute pressure).
Yesterday the rep called, and said "Bad news, the chain is not moving, and that they have to pull out the engine, which will cost $2,145 out of my pocket, so they can investigate first what is wrong". The rep stated it could be time-chain sprocket or Balance shaft went bad, that "these M157 engines are known to have those problems". Does this sound right?
I was reading about the CAM SOLENOIDS which they cleaned that
"As part of the variable valve timing (VVT) system, the camshaft adjuster solenoid is responsible for allowing oil to adequately flow through the VVT system upon its engagement. The VVT system engages to deliver extra power to the vehicle when its traveling under added stress, such as when it is carrying a larger, heavier load, or when traveling uphill. Since the solenoid is necessary in order to allow oil to lubricate the timing chain and gears, if oil cannot reach these parts then too much friction can cause them to wear out quickly. This can lead to engine failure and expensive repairs."
Could it be he miss-installed, or damage the solenoids as they took them out? The car was running fine before, but if the sprocket is damaged, they claim a poor known design from AMG, not the lubrication that might happened.
Anyone else experienced anything similar? I will update the post next week when I hear more....
JKSpeed is offline
post #2 of 4 (permalink) Old 05-02-2019, 06:34 PM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 278 Post(s)
I am no expert on these engines but the facts,,,it was fine before,,,then they work on the solenoids,then it misfires,,,then it breaks down,,,
all too much to be just a coincidence.
I feel sorry for you,,,good luck with your battle for justice...
Another example of inept mechanics causing more problems than they fix...
mattml430 likes this.
Benzyle is offline
post #3 of 4 (permalink) Old 05-03-2019, 03:14 AM
mattml430's Avatar
Date registered: Sep 2008
Vehicle: 2000 ML55 sold😢 2013 ML500,😁 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
Quoted: 767 Post(s)
I agree with Benzyle It goes in for a door lock and transmission service and is not running correctly before you even leave. I would be furious with them.
I had a Friends M156 engine that I had to replace because of the cam issue but havent heard of the 157 with issues.
I would want an independent mechanic there at the pull down to inspect it was reassembled correctly when they repaired it.
I feel for you and really hope they come to the party for you. Good luck.
mattml430 is online now
post #4 of 4 (permalink) Old 05-11-2019, 01:19 PM
mattml430's Avatar
Quoted: 767 Post(s)
Total: $3,841
Any update on this situation for you yet.
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > General AMG
My 190E hath descended into Mechanic's Hell! 85BabyBenz W201 190-Class 38 11-05-2014 07:05 PM
need help locating upshift delay switchover valve on 93 s600. orientalexpress W140 S-Class 11 11-23-2009 10:59 AM
Desperate to understand cost of engine... PopcornDude W124 E,CE,D,TD Class 18 07-18-2009 09:38 AM
ML63 introduced at 2005 Frankfurt Auto Show GregW / Oregon W164 M-Class 8 09-16-2005 09:11 AM
Long sucess history Zé Bocaina G-Class 3 05-27-2005 01:19 PM
