VIN CONFIRMATION - Page 2 - Mercedes-Benz Forum
post #11 of 13 (permalink) Old 03-02-2014, 10:26 AM
Outstanding Contributor Always Remembered RIP
eric242340's Avatar
Quoted: 334 Post(s)
Originally Posted by AMGBlackSeries View Post
Hi all,
I need your help in determining whether the G I bought is a G500 or G55.
It has all the bits and pieces consistent with being a genuine g55, wheels, badges, etc. as well as the most telling sign of all the 5.5 liter v8 AMG engine. But I got concerned when I checked the VIN on the russian vin decoder website when results that came back said it to be a G500.
Perhaps someone can help me, VIN is as follows: WDB4632481X125432
Thanks in advance!
It is slated as a G500 but the 463246 is an AMG and a true G55.
Main data
Parameter Value
Ident. number (FIN) WDB4632481X125432
Baumuster 463248
Sales name G 500 4X4 2850
Cabin 463832 10
Permanent link VIN: ???????? VIN ??????????? Mercedes-Benz | CARInfo
Order number 6 0 880 00311
Delivery date 2001-05-25
PAINT1 9744
Engine 113982 60 026173
Front axle 1 730390 1R 117848
Variant
C 006 015 058
Number for spare parts
7303901
eric242340 is offline
post #12 of 13 (permalink) Old 03-03-2014, 08:19 PM
Date registered: Feb 2014
Vehicle: 2008 clk63 AMG Black Series
Post Help VIN Confirmation G55
Hi Eric,
Thanks for your reply. As you can imagine this issue caused me much stress, but thankfully, everything seems to be in order after all.
After much research from various sources it seems some first gen g55's (if not all) are identified as g500s on vin check, but can be correctly identified by the engine indicated. In this case 113.982 which is the AMG 5.5. Another indicator would be the SA codes, ZY2 in this case for AMG 5.5. Also came across a document from AMG identifying Baumuster 463 248, 463 243 and 463 246 as G55 AMGs (attached).
Hope this info, your reply, and the rest of the thread will help future inquiries.
Now I can continue to enjoy my g55. Thanks again to you all!
AMGBlackSeries is offline
post #13 of 13 (permalink) Unread 07-21-2019, 11:22 AM
Date registered: Jun 2015
Vehicle: W201 190D 2.5 1991
Hello,
It looks like Iíve got same issue.
Iíve got G55 amg 2002 from Japan and
decoder says itís g500 4x4.
But itís AMG and Iíve got ZY4 code.
The question is...
I need to find proper diff fluid and according to
WIS For normal G500 itís 85W90 for 55 AMG itís 75W140...
So which one oil I should use?
Thanks
Kuba Kalinowski is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > General AMG
OEM Sub rip out - need confirmation luckyrdm W220 S-Class 4 06-27-2011 10:24 PM
Confirmation for Z GeeS Off-Topic 8 09-10-2010 11:59 AM
Need your confirmation rondor2 W126 S,SE,SEC,SEL,SD,SDL Class 10 09-16-2009 05:20 PM
Slow confirmation mlfun Off-Topic 9 01-25-2009 04:59 AM
Need confirmation on diagnosis broker218 W202 C-Class 2 04-28-2004 07:28 AM
