Slamming the rear hatch door: Is it normal? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-15-2019, 10:10 PM Thread Starter
Abstracted's Avatar
Date registered: Aug 2018
Vehicle: 2011 G55 AMG
Quoted: 6 Post(s)
2011 G55
I've got to slam the rear hatch door to keep the warning from appearing in the center console from coming on.
If I close it softly, even though it's fully closed and flush with the exterior of the truck, the warning that the hatch is open will will come on.
I've got to slam it so hard, I'm sure it's going to screw up the internals sooner or later.
Is this normal?
If not, is there something I can adjust so that it doesn't require that I slam it shut?
Abstracted is offline
post #2 of 4 (permalink) Old 04-16-2019, 03:26 AM
thanito's Avatar
Date registered: Aug 2009
Vehicle: 2002 MB G400CDI-1992 MB 300E-24- 2005 Mini Cooper S
Quoted: 8 Post(s)
Originally Posted by Abstracted View Post
2011 G55
Is this normal?
Maybe check the position/condition of the door switch?
Sent from my CLT-L29 using Tapatalk
thanito is offline
post #3 of 4 (permalink) Old 04-16-2019, 02:44 PM Thread Starter
Abstracted's Avatar
Quoted: 6 Post(s)
Both internal hatch door switches were just replaced a few days ago.
post #4 of 4 (permalink) Old 04-16-2019, 04:02 PM
thanito's Avatar
Quoted: 8 Post(s)
For this reason? Did you check the cabling? If you close it softly and then you push it hard inwards while the error is reproduced, does it work?
thanito is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Wagon Rear Hatch Wiper Wiring Issue hages1673 W124 E,CE,D,TD Class 3 12-11-2016 09:55 AM
Rear Hatch Latch Stuck Closed with Hatch Open SarsfieldML270 W163 M-Class 2 10-15-2016 04:44 AM
Option codes list (make sticky or move to tech links) DieselKraut W123 E,CE,D,CD,TD,TE Class 12 08-18-2014 04:43 PM
Two W108's parting out JustPassinThru Vintage Mercedes-Benz 63 07-17-2012 01:11 AM
Suspension and Handling guide - late Carroll Smith Bazzle R170 SLK-Class 3 06-20-2006 07:29 AM
