1980's Mercedes 240GD W460 - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 12-07-2018, 12:26 PM Thread Starter
g34ry's Avatar
Date registered: Feb 2011
Vehicle: 2002 ML320
Quoted: 2 Post(s)
Does anyone know if the 240GDs come with heating assembly? If so where would it be located in the engine compartment.
Any info is greatly appreciated. Thanks.
g34ry is offline
post #2 of 10 (permalink) Old 12-09-2018, 05:22 AM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 848 Post(s)
What is a "heating assembly"?
rumb is offline
post #3 of 10 (permalink) Old 12-09-2018, 04:34 PM Thread Starter
g34ry's Avatar
Vehicle: 2002 ML320
Quoted: 2 Post(s)
Sorry, I meant heater assembly.
g34ry is offline
post #4 of 10 (permalink) Old 12-10-2018, 04:23 AM
DUTCH's Avatar
Vehicle: 2000 G500 NMLE
Quoted: 124 Post(s)
Preheater for the engine or heater to warm the cabin?
DUTCH is offline
post #5 of 10 (permalink) Old 12-10-2018, 12:38 PM Thread Starter
g34ry's Avatar
Vehicle: 2002 ML320
Quoted: 2 Post(s)
It’s the heater to warm the cabin.
g34ry is offline
post #6 of 10 (permalink) Old 12-10-2018, 01:57 PM
AlanMcR's Avatar
Vehicle: 96 G300DT
Quoted: 112 Post(s)
As far as I know all Gs came with a heater. It is in the big, hard to get to, plastic box in the dash. That is where the fan is too. The heater valve is the round thing on the heater hose in the engine compartment on the right side of the air intake scoop.
AlanMcR is offline
post #7 of 10 (permalink) Old 12-22-2018, 05:19 AM Thread Starter
g34ry's Avatar
Vehicle: 2002 ML320
Quoted: 2 Post(s)
Thanks Alan. Is it the round thing I have circled in red or green in the picture below?
And is the heater unit with the fan in the black box in the middle of the dashboard?
Sorry for all these questions. Totally newbie here.
ID:	2474832   Click image for larger version
ID:	2474836   Click image for larger version
ID:	2474838   Click image for larger version
ID:	2474840   Click image for larger version
ID:	2474844   Click image for larger version
g34ry is offline
post #8 of 10 (permalink) Old 12-25-2018, 08:35 PM
AlanMcR's Avatar
Vehicle: 96 G300DT
Quoted: 112 Post(s)
Here. With the heater hoses running to both sides. There should be a bowden cable going to it that moves when the heater lever (middle one under the radio) is moved. The lever is most of the way to "warm", so you should have heat. Most likely the motion isn't getting transferred over to the valve. That will take some diagnosing.
Name:	2474832d1545484331-1980s-mercedes-240gd-w460-8be15fc3-5a11-4f86-9ebd-94a92f61738d_1545484331026.jpg
AlanMcR is offline
post #9 of 10 (permalink) Old 12-26-2018, 10:18 AM Thread Starter
g34ry's Avatar
Vehicle: 2002 ML320
Quoted: 2 Post(s)
Thanks for pointing where it is.
I did some diagnostic today and noticed when the engine running and heater turned on with the middle lever moved all the way to the right, the intake hose (red circle) was hot but the output hose (green) was cold.
Could it be the heater core (exchanger)? If so, is there an easy way to replace that or do I have to remove the dashboard?
g34ry is offline
post #10 of 10 (permalink) Old 12-26-2018, 12:15 PM
AlanMcR's Avatar
Vehicle: 96 G300DT
Quoted: 112 Post(s)
It is certainly possible that it is the core. But first verify that the valve is opening. That white lever on the side of the valve is what open/closes the flow. See if it moves with the lever. Failing that take the valve off of the car and look through it.
You can check the core for flow by taking off the hoses and blowing through it. I'd work pretty hard at non-destructively clearing it out. Because ...
Changing the heater core is a big job. Most of the dash has to come out. Then the heater box has to be split to get to the core, fan, and the fan resistor. If you are in that far, replace all of them.
AlanMcR is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
