280ge remove/replace engine... anyone got the procedure? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-10-2003, 06:24 PM Thread Starter
toka's Avatar
Date registered: May 2003
Vehicle: 82 280GE LWB RHD
Found a 280GE engine for my 280GE... only difference is mine is auto, it was manual trans, and it does not come with the intake manifold or starter.
Got the overhead pipe in the garage rigged to do the extraction, ready to blast off the grunge underneath.
Does anyone have step by step instructions(or is there a manual on-line or which someone can scan and send to me?).
In the past (other cars) I usually just take lot's of photographs and start unbolting, but a little expertise is always appreciated.
Also, when it is out, what should I do as routine care and feeding? I plan to have my starter rebuilt in hopes that will solve the delayed cranking (the longer it sits, the longer I have to hold the key before it cranks... up to 60 seconds).
Finally, if the speedometer works, but the odometer doesn't, is this an easy fix, or a send out to the experts?
Thanks
Toka in New Zealand (where G's are few)
toka is offline
post #2 of 6 (permalink) Old 09-11-2003, 01:37 AM
Arnd's Avatar
Vehicle: 1987 280GE
Yes, but ...
... only in german language!
If that would be no problem for you, I can post the part of the workshop-manual (PDF, about 7MB)
Greetings, Arnd!
Arnd Goetz
<a href="
traget="_blank">
href="
traget="_blank">www.g4rce.net/editor/</a>
Arnd is offline
post #3 of 6 (permalink) Old 09-11-2003, 02:15 AM
Date registered: Jan 2003
Vehicle: 1986 LWB 300GD 6-2
Re: Yes, but ...
Hallo Arnd,
no problem it being in German.
I was born and raised in Hamburg.
Thanks for your help !
Cheers from Canada
Greetings, Arnd!
1986 300GD Puch 6-2
1987 500SL AMG
1985 300 GD 5Door
ELRUBIO is offline
post #4 of 6 (permalink) Old 09-11-2003, 03:48 AM
Arnd's Avatar
Vehicle: 1987 280GE
Here it is ...
I have put it on my webserver, cause I don't want to clog up your eMail-Account [;)]
http://www.g4rce.net/download/W460-2...useinbauen.pdf
'G'reetings, Arnd!
Arnd Goetz
<a href="
traget="_blank">
href="
Arnd is offline
post #5 of 6 (permalink) Old 09-11-2003, 04:17 AM
Re: Here it is ...
THANKS ARND ![:D]
1986 300GD Puch 6-2
1987 500SL AMG
1985 300 GD 5Door
ELRUBIO is offline
post #6 of 6 (permalink) Old 09-12-2003, 01:05 AM Thread Starter
toka's Avatar
Re: Yes, but ...
Greetings, Arnd!
Hi Arnd (and ElRubio who seemed to have answered for me). I downloaded your PDF, had Adobe convert it to a TIF file, then used a Text converter to convert the images into text html, copied that into Word (stripping out the photographs) and then used a translator that Word clicks to on the web. Below is the German, and the translation. Would one of you be so kind as to read the translation and clean it up? I'll then try to put it back together. Thanks Toka
1
Motor aus- und einbauen 01.63Anziehdrehmomente in Nm
Motor an Getriebe 55Motortragarme an Motorlager 35—40Auspuffrohr an AuspuffkrOmmer 20AblaBschraube an Kuhler 6—10Gelenkwelle an Getriebeflansch 35Getriebeträger an Rahmen und Getriebe 47Drehmomentwandler an Drehmomentblech (Automat. Getriebe) 42Handelsubliche Werkzeuge
Motordirigent, GroBe 1,5 z. B. Firma Backer, 5630 RemscheidBestell-Nr. 3178Ausbauen
I Motorhaube hochstellen. Kleinen Haubenhal-ter am Anschlag aufsetzen.
2 Massekabel an der Batterie abklemmen.3 KUhlerverkleidung ausbauen._ ~ Motoren, Band 2 — Nachtrag 2 — Erweiterung — Oktober 1982 01011
1
2
U1.t53 Motor aus- und einbauen4 KUhlerhalterungen (1) an der oberen Quer- strebe abschrauben.5 Befestigungsschrauben (2) der oberen Quer-strebe und der Längsstrebe herausschrauben.6 Bowdenzug am HaubenschloB lOsen, Steckver-bindungen am Horn abziehen. Querstrebe mitLangsstrebe abnehmen.
7 KOhlmittel am KUhIer ablassen.
8 Oberen und unteren Kuhlmittelschlauch amKUhler losen und abziehen.
9 OlkUhlerleitung oben am OlkUhler abschrau-ben, dabei den eingelOteten Stutzen gegenhalten.
10 KUhier an der unteren Halterung (1) abschrau-ben und aus den Haltern herausheben.
11 OlkUhierleitung unten am Olkuhler abschrau-ben, dabei den eingelOteten Stutzen gegenhalten.
12 KOhier und OIkUhler herausheben (auf Visko-selUfter achten).
010/2
2
3
Motor aus— und einbauen 01.6313 Binder an der Manschette (Pfeil) Ibsen undManschette vom Luftfilter abziehen.
14 Hutze am Gemischregler (Pfeile) abschraubenund abnehmen.
15 Diagnosesteckdose (1) abschrauben, Kabel-stecker abziehen, Abdeckkappe (2) der Zundspuleabnehmen, Kabel — Klemme 15 — abschrauben.
16 Kabelstecker (3) am Schaltgerat abziehen.
17 Kabelstecker am Kaltstartventil (1) und am Si-cherheitsventil (2) abziehen. Massekabel (3) amSaugrohr abschrauben.Motoren, Band 2 — Nachtrag 2 — Erweiterung — Oktober 1982 010/3
3
4
01.63 Motor aus— und einbauen18 Unterdruckleitung am Saugrohr abschrauben.
19 Krattstoff-Saugleitung (1) und ROcklauflei- tung (2) am Kraftstoffmengenteiler abschrauben.
20 Druckleitung (1) und RUcklaufleitung (2) ander Servolenkung abschrauben.
21 Kabelstecker am Warmlaufregler abziehenund Kabel am Oldruckgeber abschrauben.
22 Gasgestänge (1) an der Längsregulierwelle (2)aushangen. Federklammer (3) abziehen undLangsregulierwelle herausnehmen.
23 Massekabel (4) an der Stirnwand ab-schrauben.
24 Elektrische Leitungen an Anlasser und Licht-maschine abziehen bzw. abschrauben. Masse-band am Kupplungsgehäuse abschrauben.
010/4
4
5
Motor aus- und einbauen 01.6325 Kabelstecker am KUhlm itteltemperaturgeber(1) und am Temperaturgeber für Kaltstartventil (2)abziehen.
26 Heizmittelleitungen an Stirnwand (1) und Zu-satzheizung (2) lOsen und abziehen.
27 Warmeschutzblech (1) am AuspuffkrOmmerabschrauben. Beide Auspuffrohre am Auspuff-krUmmer abflanschen.
28 Zwischenstrebe (1) und Getriebetraverse (2)ausbauen.Motoren, Band 2 — Nachtrag 2 — Erweiterung — Oktober 1982 010/5
5
6
01.63 Motor aus- und einbauen29 Gelenlcwelle am Getriebe abschrauben.
Mechanisches Getriebe
Hinweis: Beim Abbau der Gelenkwelle auf Zen-trierflansch (Pfeil) achten.
Automatisches Getriebe
30 Sicherungen an den Schaltgestangen abneh-men. Schaltgestänge von den Schalthebein ab-drUcken bzw. Schaltgestänge mit Schaithebeinvon den Schaltwellen (1) abnehmen.
31 Entlüftungsleitung (2) am Getriebe und (3) amKupplungsgehäuse abschrauben bzw. abziehen.Entlüftungsbohrung am Getriebe verschliel3en.
010/6
6
7
32 Halter für Hydraulikleitung (1) zum Nehmerzy-under am Getriebegehäuse abschrauben.
33hangen.Wahlstange (2) am Bereichswahlhebel (3) aus-34 Stecker (1) für Startsperr- und Rückfahrlicht-
schalter sowie Stecker für Magnetventil abziehen.
Automatisches GetriebeMotor aus- und einbauen35 Halter für AuspuffrohrAuspuffrohr abschrauben.
36 Elektrisches Kabel amtil (2) abklemmen.am Getriebe sowie am
Kick-down Magnetven-37 Massekabel am Motorflansch abschrauben.
38 Motor am Motordirigent anhängen. Befesti-gungsschrauben an beiden Motorlagern heraus-schrauben.
39 Motor mit Getriebe herausheben und aufBocke absetzen.01.63Motoren, Band 2 — Nachtrag 2 — Erweiterung — Oktober 1982 010/7
7
8
01.63 Motor aus- und einbauen40 Getriebe vom Motor abschrauben.
Einbauen
Der Einbau erfolgt in umgekehrter Reihenfolge un-ter Beachtung folgender Punkte:
Sämtliche Heiz- und Kühlmittelschuauche prüfen,nach Befund erneuern.Gummilager prüfen, nach Befund erneuern.Hinteres Getriebelager erst nach dem Einbau vonGelenkwelle, Schautgestange sowie den Entlüf-tungsleitungen von Getriebe und Kupplungsge-häuse einbauen.Kühlsystem auf Dichtheit prüfen. Olstand der Ser-volenkung richtigstellen.Hydraulische Kupplungsbetätigung entlüften.
Die beiden dünnen Kabel am Anlasser dürfennicht verwechselt werden.
010/8
8
1 Engine dismount and install 01.63Anziehdrehmomente in nm engine at gearbox 55Motortragarme at engine mounting 35-40Auspuffrohr at AuspuffkrOmmer 20AblaBschraube at Kuhler 6-10Gelenkwelle at gearbox flange 35Getriebetraeger at limits and gearbox 47Drehmomentwandler at torque sheet metal (automat Gearbox) 42Handelsubliche of tools engine conductor, rough one 1.5 z. B. Company Backer, 5630 RemscheidBestell NR. 3178Ausbauen I hood put up. Small hood handle at the stop take up.
2 earth cables at the battery disconnect.3 KUhlerverkleidung dismount._ ~ engines, strap 2 - supplement 2 - extension - October 1982 01011 1 2 U1.t53 engine out and einbauen4 KUhlerhalterungen (1) at the upper crosswise strives undoes.5 fixing bolts (2) of the upper tie bar and the longitudinal strut turn counter-clockwise.draw to 6 bowden cable at the HaubenschloB, patch cords at the horn remove. Tie bar along-also-strives decreases.
7 Kohl means at the KUhIer discharge.
more amKUhler draw to 8 upper ones and lower Kuhlmittelschlauch and remove.
9 OlkUhlerleitung above at the OlkUhler undo, the eingelOteten connecting piece counterhold.
10 KUhier at the lower mounting plate (1) undo and from the holding lift out.
11 OlkUhierleitung down at the Olkuhler undo, the eingelOteten connecting piece counterhold.
12 KOhier and OIkUhler lift out (on Visko more selUfter respected).
010/2 2 3 Engine dismount and install 01.6313 binders at the bellows (arrow) to Ibsen and bellows from the air cleaner remove.
14 scoop in the metering unit (arrows) abschraubenund remove.
15 diagnostic plug socket (1) undo, connectors remove, cap (2) the Zundspuleabnehmen, cable - clamp 15 - undo.
16 connectors (3) to switchingturned out remove.
17 connectors at the cold weather starting valve (1) and at the relief valve (2) remove. Earth cable (3) amSaugrohr undo.Engines, strap 2 - supplement 2 - extension - October 1982 010/3 3 4 01.63 engine out and einbauen18 vacuum piping at the suction tube undo.
19 Krattstoff intake (1) and ROcklauflei tung (2) at the amount of fuel divisor undo.
20 pressure pipe (1) and jerk run line (2) other power steering undo.
21 connectors at the warming up control device abziehenund cables at the old jerk giver undo.
22 gas linkages (1) at the longitudinal adjustment shaft (2)aushangen. Spring clip (3) remove and-long-adjust-waves take out.
23 earth cables (4) at the front panel undo.
24 conductions at starter buttons and generator remove and/or. undo. Ground strap at the clutch housing undo.
010/4 4 5 Engine dismount and install 01.6325 connectors at the KUhlm itteltemperaturgeber(1) and at the temperature transmitter for cold weather starting valve (2)abziehen.
draw to 26 heating medium lines at front panel (1) and additional heating system (2) and remove.
27 warm shield (1) at the AuspuffkrOmmerabschrauben. Both exhaust pipes at the exhaust-bent flange.
28 intermediate rod (1) and gearbox cross beam (2)ausbauen.Engines, strap 2 - supplement 2 - extension - October 1982 010/5 5 6 01.63 engine out and einbauen29 Gelenlcwelle at the gearbox undo.
Mechanical gearbox Note: Pay attention with the dismantling of the drive shaft to centering flange (arrow).
Automatic gearbox 30 fuses in the Schaltgestangen remove. Schaltgestaenge of Schalthebein print and/or. Schaltgestaenge with Schaithebeinvon the control shafts (1) remove.
31 breather pipe (2) at the gearbox and (3) amKupplungsgehaeuse undoes and/or. remove.Bleed bore at the gearbox verschliel3en.
010/6 6 7 32 handles for hydraulic line (1) to Nehmerzy more under at the gear-box undo.
33hangen.Selecting shaft (2) at the range selection lever (3) aus-34 plug (1) for starting closing and back headlight switches as well as plugs for single solenoid valve remove.
Automatic gear motor out and einbauen35 handle for exhaust pipe exhaust pipe undo.
36 electrical cable amtil (2) disconnect.at the gearbox as well as to Kick-down Magnetven-37 earth cable at the engine flange undo.
Automatic gearbox 38 engine at the engine conductor attach. Fixing bolts at both engine mountings turn counter-clockwise.
39 engine with gearbox lifts out and jacks up sets off.01.63Motoren, strap 2 - supplement 2 - extension - October 1982 010/7 7 8 01.63 engine out and einbauen40 gearbox from engine.
Install The installation takes place in reverse order considering the following points: All heating and Kuehlmittelschuauche examine, after findings renew.Rubber bushings examine, after findings renew.Rear gearbox bearing only after the installation of drive shaft, Schautgestange as well as the breather pipes of gearbox and clutch housing install.Cooling system for tightness examine. Olstand of the power steering rectify.Hydraulic clutch manipulation bleed.
The two thin cables at the starter button not to be confounded.
010/8 8
toka is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
