2002 G500 sunroof problem - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 04-06-2013, 01:45 PM Thread Starter
Date registered: Apr 2013
I have a 2002 G500. Yesterday I started noticing my sunroof not functioning properly. It was going real slow opening and retracting. Today it's not working at all. I can manually (with my hands) open it and shut it. However I cannot shut it all the way, the back will not come up all the way. The motor is still running I've removed the cover on the rear driver's side and see both wheels spinning. I need advice, I assume it has something to do with the cable but have no clue where to go from there. Also, if nobody has a fix for that is there a way to manually close it to where the sunroof will come up all the way in the back so I can avoid rain leaking and road noise. Thanks all!
therron4ou is offline
post #2 of 8 (permalink) Old 04-06-2013, 04:04 PM
DUTCH's Avatar
Vehicle: 2000 G500 NMLE
Quoted: 124 Post(s)
I'll ass=u=me that it is somewhat similar to the 2000 sunroof. Check your owners manual to be sure.
DUTCH is offline
post #3 of 8 (permalink) Old 04-06-2013, 07:54 PM Thread Starter
Thank you for the reply! However, the motor is working just fine. I believe the cable is the problem. So I really need a way to close it without using the motor or a way to replace the cable. Any help will be greatly appreciated.
post #4 of 8 (permalink) Old 04-07-2013, 02:25 AM
DUTCH's Avatar
Quoted: 124 Post(s)
Did you try closing it manually as shown in the PDF posted above? Is it possible that the motor clutch is slipping?
DUTCH is offline
post #5 of 8 (permalink) Old 04-07-2013, 06:25 AM Thread Starter
I guess it could be. I'll try it and update
post #6 of 8 (permalink) Old 04-07-2013, 09:26 AM Thread Starter
Ok the wheel on the motor is spinning just fine. My guess is that it has go be the cable.
post #7 of 8 (permalink) Old 04-07-2013, 10:17 AM
DUTCH's Avatar
Quoted: 124 Post(s)
Maybe one of these will help. Good luck!
DUTCH is offline
post #8 of 8 (permalink) Old 04-07-2013, 12:45 PM
AlanMcR's Avatar
Vehicle: 96 G300DT
Quoted: 109 Post(s)
Chances are that the mechanism in the roof is gummed up. It is the same mechanism as a W216 or W140, so an MB shop should know how to deal with it.
If you want to dig into the internals, PM me and I can send you some manual pages covering that.
...Alan
63 230SL
96 G300DT
98 E300DT
AlanMcR is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
