Please help. - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-16-2014, 12:54 PM Thread Starter
unlukky's Avatar
Vehicle: 2014 CLS550 4Matic
Question Please help.
I drive an 06 CLS500 and have located some wheels.
They are Mandrus 20x8.5 et25 and 20x10 et 32 front and rear respectively.
I am under the impression that these should fit nicely with 245/35r/20 and 295/30r/20 front and rear. However the back is rubbing on the inside fender well. Do I need a 10mm spacer in the back or something? Please advise.
John
Theres another set of wheels locally that they guy had on his cls550 and they were 20x8.5 et32 and 20x10 et42 front and rear. I saw pictures and it looked ok, but those numbers seem way off.
2014 CLS550
unlukky is offline
post #2 of 4 (permalink) Old 02-17-2014, 01:19 PM
Supporting Vendor
Discount Tire Direct's Avatar
Date registered: Apr 2008
Vehicle: Mercedes Tires and Wheels
Thank you for the post John.
According to my fitment information your wheel dimensions are spot on. The 295 rear tires though are on the aggressive side. A spacer may fix the rubbing but we do not recommend them. I would have your local Discount Tire test fit a 285 to see if that fixes the rubbing.
Low Prices! More Choices! Trusted Experts!
At The Store:
To Your Door:
Useful Links:
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Discount Tire Direct is offline
post #3 of 4 (permalink) Old 02-18-2014, 11:41 AM Thread Starter
unlukky's Avatar
Thats what I thought too.
So what about the others? Will they work?
John
2014 CLS550
unlukky is offline
post #4 of 4 (permalink) Old 02-18-2014, 12:06 PM
Supporting Vendor
The other two wheel dimensions you noted will move the tires even closer to the inside fender liner. With narrower tires they would likely work but they will tuck inside the fender a good amount.
At The Store:
To Your Door:
Useful Links:
  Mercedes-Benz Forum > Vendors > Discount Tire Direct
