1985 Euro 300TD non-turbo primer pump removal? - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-12-2019, 10:24 AM Thread Starter
jwalk1972's Avatar
Date registered: Jul 2009
Vehicle: 1970 280sel, 1979 300d Wagon, 1971 250c
1985 Euro 300TD wagon non-turbo primer pump removal?
SOLVED
Hi,
I'm curious if I need to remove the primer pump assembly to change the primer pump? Seems a little more difficult to remove than the ones on my other US-spec 300td turbo wagon. I've read a little about M vs MW pump but not clear on why the housing is set up different or if I have to remove it to change the pump. I hope this makes sense. I just don't want to create unnecessary probs. Any help would be appreciated. I attached data info below if that helps.
FIN WDB1231901F039529
Model 300 TD
Engine 617912 12 162185
Transmission 722405 02 167866
Order Number 0 4 513 19648
Order Location BELGIUM
Interior MB-TEX - BEIGE (155)
Paint 1 MIDNIGHT BLUE (904U)
Approx. Build Date 1984-12
Code Description
286 LUGGAGE NETS ON DRIVER RESTS L AND R
411 MECHANICAL SLIDING ROOF
420 AUTOMATIC TRANSMISSION 4-GEAR
438 ELIMINATION OF REAR SAFETY BELTS
440 TEMPOMAT (CRUISE CONTROL)
466 CENTRAL LOCKING MECHANISM
543 SUN VISOR WITH VANITY MIRROR, ILLUMINATED, LEFT AND RIGHT
570 FOLDING ARMREST, FRONT
584 ELECTRIC WINDOW LIFTERS (FRONT AND REAR DOORS)
593 HEAT-INSULATING GLASS, ALL-AROUND, HEATED REAR WINDOW PANE (SINGLE-SHEET SAFETY GLASS), BAND FILTER
ID:	2527358   Click image for larger version
jwalk1972 is offline
  Mercedes-Benz Forum > General Mercedes-Benz Forums > Diesel Discussion
